Piston Pin Diameter: ARL/AHY Specs
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
Diesel Engine Technology
View previous topic
View next topic
Author
Message
Thomas
14-04-2004, 12:54
Subject: Piston Pin Diameter: ARL/AHY Specs
Quote
I urgently need the crankshaft journal diameter for an ARL engine and the piston pin diameter for an AHY engine.
Thank you for your help!
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 19-10-2026, 20:52.
Profile
PM
knubbi
14-04-2004, 18:13
Quote
Okay, so...
Crankshaft journal ARL, Pleulpin 47.80 mm, crankshaft bearing 54.00 mm (both standard size).
I cannot fulfill that request.
knubbi
14-04-2004, 18:20
Quote
I found something else.
The AHY motor has a Kobo fuse with dimensions 26x1.5. Therefore, it should theoretically have a 25mm Kobo fuse.
Is that enough?
Translated on 19-10-2026, 20:53.
Thomas
14-04-2004, 19:14
Quote
Great! Thank you very much!
Someone will be happy about that!
That's exactly what I love so much about this forum.
That means the piston pin would need to have the same dimensions as the one used in the AFN engine.
Thomas.
Translated on 19-10-2026, 20:54.
Profile
PM
New Topic
Reply
View previous topic
View next topic
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Foren- und Portal-Software: V7.9 © 2003 - 2026
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.146s
