ASZ with engine control unit coding 00005 !?
Post20-04-2004, 17:07    Subject: ASZ with engine control unit coding 00005 !? Quote
I just tried using the search function, but I only found the codes 00001 or 00002 (for manual transmission or automatic transmission, respectively) when searching for encoding information.
My engine is coded with 00005 icon_eek.gif icon_exclaim.gif.
Part number: 038 906 019 LA
next window: 0400 SG 5405
Software code: 00005
Under "Extras," you'll find the FIN (Vehicle Identification Number), and in the same window, there's another long number that I haven't been able to identify yet.
Using the VAGCOM "coding" function, I'm accessing the programmed value of 00005.
Does anyone know what's behind this, and whether there are also "installable" software programs hidden behind the codes 00001 to 00004?
Can I temporarily reprogram this part (out of curiosity) without risking any permanent issues, even after reverting it back to the original value of 00005?
98er_alh
Post20-04-2004, 19:14    Subject: ASZ with engine control unit coding 00005 !? Quote
Very interesting!
Speculation mode on: Is there a "break-in" program that switches to normal or full power at a certain mileage (xy km)? There have been occasional reports of sudden power increases. Speculation mode off.
It was just my first thought.
but Ulf, you'll explain it, I'm sure.
It's good that we have you; I don't think even at a mass-market company would they take it this seriously.
Best regards, Andreas.
Avatar-Jan6K
Post20-04-2004, 20:11    Subject: ASZ with engine control unit coding 00005 !? Quote
Hi UIf,
*grin*
I also have "00005" as the encoding for my ASV, and the speculations in the relevant thread went nowhere, and you also participated in those speculations.
/viewtopic.php?t=5002&highlight=00005
I haven't come any further than I did back then, but I'm glad that I'm not the only one who feels that way.
"Next time I connect the VAGCOM (it's not easy because of the power supply, but I'll try to do it in the next few days), I'll pay attention to the coding. That should clarify the issue with the initial setup." The engine, which had approximately 5000 km on it when I got it, now has 38000 km, and the break-in period is long over.
Jan.
1Z5 CFHF / AHB H4D
Gremlin
Post20-04-2004, 20:53    Subject: ASZ with engine control unit coding 00005 !? Quote
Skoda Octavia station wagon, 07/03, ASZ engine, 6-speed transmission.
Address 01 -------------------------------------------------------
Controller: 038 906 019 HJ
Component: G000SG 5259
Coding: 00002
Shop #: WSC 31480
maybe 00005 is the fabric softener program for mobile ashtrays icon_twisted.gif.
CU Gremlin.
Post20-04-2004, 21:27    Subject: ASZ with engine control unit coding 00005 !? Quote
Jan6K wrote:
Hi UIf,
*grins*
Hi Jan,
I was looking for icon_redface.gif, but unfortunately, a thread on the topic of coolant heating systems was filtered out by my "could-be-relevant" filter.
@gremlin:
If 00005 is the ashtray coding, it doesn't apply to me (I don't smoke and use the ashtray as a storage for small items) -> how should I code my car instead icon_wink.gif icon_question.gif icon_question.gif
Avatar-Jan6K
Post20-04-2004, 22:43    Subject: ASZ with engine control unit coding 00005 !? Quote
Well, there it is – the solution!
I am also a non-smoker, and I use the ashtray as a storage space for small items. So, 00005 is exactly that: the non-smoker code for ashtrays that are used as storage for small items.
Okay, I'll try to find some time in the next few days to check the readings. Then we'll at least know if there's anything to the idea of changing the input, even though I personally don't believe it – I think it will still show a value of 00005.
Is there anything else I should check in the ASV (Auxiliary System Vehicle) in this context (since the battery isn't sufficient for driving, and the car's power supply still can't be used while the engine is running)?
@Ulf: I wasn't really serious about the search, hence the smiley. I knew I had to search for "00005" and Author=Jan6K because I remembered that I had posted it before. Therefore, it's likely that very few people would have actually been able to find it.
Jan.
1Z5 CFHF / AHB H4D
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAGCOM: Engine computer not responding Diesel Engine Technology
No new posts Randthema: Rätselhafter Steuereingang am PD-Motorcomputer Diesel Engine Technology
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts Reprogramming new engine computers: is it possible withou... On-Board Diagnostics (OBD)
