Which AHF fuel injectors?
scherle
Post28-04-2004, 10:14    Subject: Which AHF fuel injectors? Quote
Hi there!
I would like to replace the fuel injectors in my Golf IV automatic transmission (AHF) with the 216 injectors. Does anyone know if the automatic transmission uses the same injectors as the manual transmission?
Best regards.
Scherle.
PrivatBereich
Post28-04-2004, 10:26    Subject: Which AHF fuel injectors? Quote
Hello Scherle,
You can figure that out yourself! Go ahead.
icon_arrow.gif on top of 'vehicle'
icon_arrow.gif Then you enter your data (e.g., via engine codes) and select your vehicle and engine.
icon_arrow.gif When selecting the assembly group, choose 'Fuel processing --> Nozzles --> Nozzle holder'.
Now you can see what types of nozzles are available for your vehicle, and whether there are different ones for automatic and manual transmissions. (For each engine, at least two part numbers are always displayed; by viewing the item details, you can see that one is equipped with a needle movement sensor (NMS) and one is not.)
Private.http://www.bosch-automotive.com/ecat-online/{MARKER}
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Welche Einspritzdüsen für ALH? Diesel Engine Technology
No new posts Welche TDIs haben die gleichen Einspritzdüsen? Diesel Engine Technology
No new posts Fuel Injection Pump: Which One? Diesel Engine Technology
No new posts Welche ist die Getriebeölablasschraube? Diesel Engine Technology
