ECU Connection Error: Troubleshooting Guide
tekkno
Post04-08-2004, 9:06    Subject: ECU Connection Error: Troubleshooting Guide Quote
Hello everyone, I'm new here.
I have set up the interface with version 4.0, but unfortunately, I am unable to connect to the control unit.
It always says:
interface status 3 - no connection to the control unit, or: the control unit is not responding icon_sad.gif
Now my question: Does version 4.0 actually work? Has anyone here ever tried it out?
I'm trying to read the error codes from my VW Corrado VR6 (although it's not a diesel icon_biggrin.gif). It still has the 2x2 connectors under the shift lever.
During the LED test, LEDs 1 and 2 are blinking.
'Doesn't the Corrado have both a K-line and an L-line? I modified the adapter so that the switching between K/L-line and K/K-line is no longer necessary, and now it only has a K/L-line, as described in the manual.'
Can someone explain how this specific adapter works? I can't quite imagine how the data from the car is transmitted to the PC via the K-line.
Thank you for your help.
'Hello.'
Translated on 21-08-2026, 9:35.
tekkno
Post04-08-2004, 10:40    Subject: ECU Connection Error: Troubleshooting Guide Quote
Does anyone have any advice?
Okay, the adapter is working perfectly; I tested it on my workbench. I simulated responses from both the PC and the car, and the adapter shows logical switching states. Based on that, I think I assembled it correctly.
Do I perhaps need to enter something specific in the options of VCDS (formerly VAG-COM), such as the baud rate, etc.?
'Thank you.'
'Hello.'
Translated on 21-08-2026, 9:37.
tekkno
Post04-08-2004, 13:01    Subject: ECU Connection Error: Troubleshooting Guide Quote
Okay, so it turns out, I can now access my control unit icon_biggrin.gif. I can read the data from the engine control unit and the ABS control unit icon_smile.gif.
Can anyone tell me where the OBD2 port is located on a VW T4?
'Thank you.'
'Hello.'
Translated on 21-08-2026, 9:39.
wolfi_b
Post04-08-2004, 13:52    Subject: ECU Connection Error: Troubleshooting Guide Translating...
[Translating...]
http://www.openobd.org/einbauorte.htm
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
tekkno
Post04-08-2004, 14:18    Subject: ECU Connection Error: Troubleshooting Guide Quote
Thanks, the website is really great.
'Hello.'
Post04-08-2004, 18:12    Subject: ECU Connection Error: Troubleshooting Guide Quote
Okay, so it would be great if you could let me know what the problem was in the first place...
Translated on 21-08-2026, 9:40.
tekkno
Post05-08-2004, 7:29    Subject: ECU Connection Error: Troubleshooting Guide Quote
I just had to set the VR4 to its maximum setting, and then it worked icon_biggrin.gif.
'Hello.'
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Connecting to the Audi 8B4 TDI engine control unit with V... On-Board Diagnostics (OBD)
No new posts Skoda Octavia: No Connection to Heater Control Unit Electrical Systems, Vehicle Electronics, Multimedia
No new posts Unable to establish connection (diagnostic line) Diesel Engine Technology
No new posts Control Unit Failure (VAG): No Power & Clicking Noise On-Board Diagnostics (OBD)
