Clutch Slipping? Get Help Now!
donalexo
Post11-07-2005, 22:57    Subject: Clutch Slipping? Get Help Now! Quote
Hello everyone!
After the engine overhaul, including a performance upgrade, my clutch now starts to slip approximately 3,000 kilometers later. The slippage occurs precisely at the engine's peak torque (between approximately 1800-2200 RPM).
Of course, the clutch with almost 180,000 km is not exactly new, but I had expected it to last longer icon_cry.gif.
My base AGR engine doesn't have a dual-mass flywheel (DMF) yet, and therefore has a 228-sized clutch disc. Newer models with a DMF, on the other hand, have a 219-sized disc. So, I thought that the clutch should be able to handle a higher torque increase better than, for example, the clutch in an ALH engine.
The clutch should be identical in design to the one that was installed in the 1Z model.
Now I'm wondering how I should address this problem. Are there any reinforced pressure plates and reasonable friction materials (no sintered parts, but something suitable for everyday use) that can reliably handle 300-350 Nm of torque without costing a fortune?
Thank you for the tips.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 01-09-2026, 0:02.
Julian
Post12-07-2005, 20:41    Subject: Clutch Slipping? Get Help Now! Quote
*ahem*
Have you tried using the search function or Google?
Translated on 01-09-2026, 0:04.
R.M.
Karma: +14 / -0   Thank you, like it!
Post12-07-2005, 20:46    Subject: Clutch Slipping? Get Help Now! Quote
The clutches from "Sachs Race Engineering" are supposed to be very good. They can handle a lot of torque and have organic friction linings.
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch slipping on ASZ engine Diesel Engine Technology
No new posts Clutch Slipping Golf 4 TDI ALH - Fix It! Diesel Engine Technology
No new posts Coupling slipping!?! Golf IV TDI 90 PS Diesel Engine Technology
No new posts Clutch Slipping After 20,000 km? Warranty Rights. Diesel Engine Technology
