Wastegate vs. VTG: Bay 1.4 TDI Performance
Aliendrummer
Karma: +6 / -2   Thank you, like it!
Post12-07-2005, 14:42    Subject: Wastegate vs. VTG: Bay 1.4 TDI Performance Quote
Hi!
I'm interested in knowing what kind of turbocharger is installed in my engine bay.
Since I'm not an expert in this field, I just wanted to ask a question here...
CHRiS
Translated on 11-08-2026, 20:40.
Post12-07-2005, 14:46    Subject: Wastegate vs. VTG: Bay 1.4 TDI Performance Quote
afaik:
1.4L engine, 75 horsepower, waste (likely referring to a turbocharger or similar component).
1.4L, 90 HP, VTG.
I don't have the information about which one is the BAY right now.
Translated on 11-08-2026, 20:41.
Post12-07-2005, 14:47    Subject: Wastegate vs. VTG: Bay 1.4 TDI Performance Quote
Okay, according to Spritmonitor, you have 75 horsepower, which is a waste.
You should also remember that not much happens below 2200.
That's at least the case with the AMF engine (also known as the 1.4 with 75 horsepower).
Translated on 11-08-2026, 20:42.
Aliendrummer
Post12-07-2005, 14:56    Subject: Wastegate vs. VTG: Bay 1.4 TDI Performance Quote
Thank you for the quick response.
That 2,200 RPM figure is correct, but from there on out, the motor becomes really enjoyable to use.
CHRiS
Translated on 11-08-2026, 20:43.
Post12-07-2005, 15:00    Subject: Wastegate vs. VTG: Bay 1.4 TDI Performance Quote
I think so too, when you see your consumption icon_smile.gif.
I can confirm that as well.
I drove the 9N with that engine once.
Translated on 11-08-2026, 20:44.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Wastegate Calculation: Formula & Guide Diesel Engine Technology
No new posts Wastegate Question: Troubleshooting & Explained Diesel Engine Technology
No new posts Wastegate, boost control valve Diesel Engine Technology
