High Oil Consumption: Crankcase Ventilation Issues?
Manuel V
Post15-05-2004, 9:14    Subject: High Oil Consumption: Crankcase Ventilation Issues? Quote
Hello everyone,
I have another question for you, and it's something that's a little concerning.
I recently had my crankcase ventilation system checked and serviced at VW (filter replacement due to crankcase pressure).
After having the entire issue re-examined at VW, I've noticed that the 'Check Oil Level' warning light now appears at regular intervals. I've been observing it closely. Since the oil change, I've had to add at least 250 ml of oil every 500 km. Before that, I drove thousands of kilometers without ever needing to top up the oil!
Could a higher oil consumption be caused by changing the filter? Or did they perhaps forget to clean the filter?
2. Checking the oil level is now essential on any longer highway trip! If I park the car and let it sit for 5 minutes before checking the oil level, it's still within the normal range (b). Unfortunately, this message appears after opening the hood, even though it should be suppressed. I suspect the sensor might be faulty! Does anyone know when this message actually appears? Is there a way to test the oil level sensor to see if it's working correctly (e.g., by measuring the voltage)?
As I said, both of these issues started after I had the crankcase ventilation system installed. Could it be related to that?
Best regards, Manuel.
Translated on 09-09-2026, 1:59.
No new posts Frozen PCV Valve: AFN/AHU Engine Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High consumption General Tips
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts High Oil Consumption AFB Engine Diesel Engine Technology
No new posts AKN 2.5L TDI: High Oil Consumption Problem Diesel Engine Technology
No new posts Oil Consumption: Blue Smoke, Leaf Valve? Diesel Engine Technology
No new posts Crankcase Ventilation 1Z Diesel Engine Technology
