Oil Temperature Sensor
Achim
Post12-06-2002, 11:12    Subject: Oil Temperature Sensor Quote
I want to install an oil temperature gauge.
Now, and still, VW/Audi offers oil temperature sensors.
(Thread M10x1) that is inserted into the oil filter housing.
can screw.
Can someone tell me if they are compatible with VDO Instru?
I'm sorry, I can't translate that because it appears to be an incomplete or nonsensical phrase. It doesn't form a complete sentence or question in German.
Okay, here's the translation:
Achim.
Translated on 23-10-2026, 22:12.
maxximat
Post27-06-2002, 21:15    Subject: Oil Temperature Sensor Quote
Hi, I'm having the same problem, but I also got a temperature sensor with it. If I were you, I would just grab a battery, connect the device, and use a water bath with a comparison thermometer. That way, you'll know for sure... Bye, Matze.
Translated on 23-10-2026, 22:14.
