klopfer Blaumann
Joined: 03/23/2003 Posts: 70 Karma: +6 / -0 Location: Solingen 2007 Audi A4 Avant Free account, no CAN development support
26-05-2004, 21:37 Subject: Search for label file |
Hello fellow DIY enthusiasts,
Does anyone have a label file for the STG "4A0 907 401 P" that they could share with me?
What actually happens if VAG-COM doesn't find the correct file for my control module (MSG)? Will it then use a similar one? Some of the values seem implausible to me, and I want to make sure that I'm not misinterpreting the analyzed data.
Sure, here's the translation:
"Thank you in advance."
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Profile PM Garage |
Uwe@Ross-Tech Guest
27-05-2004, 3:48 Subject: Search for label file |
VAG-COM displays which label file is being used. If no suitable match is found, 'none' or 'no' is displayed, and the labels are then an estimate based solely on the data.
Please tell me your make, model, and year. Here are some label options that might be suitable for your engine: 3B1-907-401, 4B1-907-401, or 4B2-907-401. All of these are compatible with engine code AKE.
-Uwe-
klopfer Blaumann
27-05-2004, 8:54 Subject: Search for label file |
Hello Uwe,
MKB is AEL and the year of manufacture is 01/1995.
VAG-COM also always says that it doesn't have a label file (none).
Thomas.
Profile PM Garage |
