Timing Belt Problem 1Z
wolfi_b
Post03-06-2004, 10:19    Subject: Timing Belt Problem 1Z Quote
Hello everyone!
Problems upon problems... I unfortunately have to post again icon_redface.gif.
I had the timing belt replaced on my Audi 80 1Z 3000 km ago. However, yesterday I noticed that the timing belt already shows signs of wear icon_exclaim.gif. The surface (smooth side) is rough, and the lettering is barely legible. Furthermore, the timing belt is not centered and is rubbing against the edge of the tensioner pulley. In contrast, it was perfectly centered before, and the lettering is still readable on the old timing belt.
I then placed a ruler along the top and bottom edges of the front and rear wheels. They're not exactly parallel, but hopefully the slight difference will be acceptable. In any case, the top cover is screwed on correctly.
Unfortunately, I mistakenly installed a replica tensioner and idler pulley. (I won't do that again). At least the tensioner is from the same manufacturer as the original, even though it doesn't have a part number.
Could it be related to the timing belt?
I'm planning to get a new one from Continental.
Has anyone else experienced the same problem?
Greetings, Wolfi.
Translated on 01-08-2026, 1:14.
wolfi_b
Post03-06-2004, 22:29    Subject: Timing Belt Problem 1Z Quote
Hello.
I've now installed a new genuine timing belt and tensioner pulley, but the problem persists.
I've noticed that the ESP shaft has both axial and radial play. It looks like there might be bearing damage, doesn't it?
Can the bearings be replaced in an ESP (Electrostatic Precipitator)?
I'm out of ideas...
Best regards, Wolfi.
Translated on 01-08-2026, 1:17.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post03-06-2004, 23:08    Subject: Timing Belt Problem 1Z Quote
Find out if there is a modified pump console available for the 1Z. icon_eek.gif
At the AFN, it was in issue 9/97 where it was modified. icon_razz.gif
The ESP wheel can be easily moved back and forth, but definitely not radially.
B.Eng (FH) u. KFZ Meister
Translated on 01-08-2026, 1:18.
