Defective Car Control Unit: What Can You Do?
dq1
Post01-11-2003, 22:32    Subject: Defective Car Control Unit: What Can You Do? Quote
Good evening!
I know it's not a diesel, but as you know, there are experts here!
Today, for the first time, I used VAGCOM to check the error memory of my A6 (two weeks old), with engine code ASN, as a preventative measure. So far, I haven't noticed any errors while driving.
VAGCOM reports:
18010 - Control unit defective.
002 - Lower limit exceeded - Intermittent.
Should I be worried about that?
Translated on 15-09-2026, 21:41.
Martin R
Post23-11-2003, 14:40    Subject: Defective Car Control Unit: What Can You Do? Quote
It is not uncommon for error codes to be stored in the control units of new vehicles.
Just delete it.
If he doesn't come back, everything will be fine.
'This happens to us quite often - usually, the word 'only' just needs to be removed.'
Translated on 15-09-2026, 21:42.
dq1
Post26-11-2003, 13:08    Subject: Defective Car Control Unit: What Can You Do? Quote
You're welcome, I'm glad I could help.
It hasn't reappeared, at least not yet.
Translated on 15-09-2026, 21:43.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Viscous Fan Screw Stuck / Jamshed Defective Diesel Engine Technology
No new posts ABS control unit new, and coding always resets to 00 On-Board Diagnostics (OBD)
No new posts Steuergerät defekt was tun ? On-Board Diagnostics (OBD)
No new posts Faulty T4 engine control unit, 2.5 TDI ACV On-Board Diagnostics (OBD)
