sven Guest
20-06-2004, 15:50 Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? |
Does my Passat from the year 1994 with engine code 1Z have an OBD2 interface?
I heard that it doesn't have one. Then I wonder what that connector is to the right of the steering wheel? It even has pins like an OBD2 port.
Translated on 21-07-2026, 8:12.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
20-06-2004, 18:19 Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? |
Yes, 1Z is okay!
Translated on 21-07-2026, 8:13.
Profile PM WWW Garage |
WarLord Guest
21-06-2004, 19:30 Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? |
It's not OBD2.
Best regards, WarLord.
21-06-2004, 19:44 Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? |
Sure, perhaps we should add that. While the diagnosis is performed via an OBD2 connector (specifically a 2x2 connector), it doesn't support the OBD2 protocol itself.
Uwe@Ross-Tech Guest
22-06-2004, 5:36 Subject: Does the Passat TDI, MKB 1Z, have an OBD2 interface? |
It cannot use OBD2 as a protocol.
Okay. But for clarity: VAG-COM uses the VAG protocols anyway, not OBD2.
-Uwe-
Translated on 21-07-2026, 8:14.
