@Thomas regarding Lupo
Michael II
Post22-04-2002, 12:29    Subject: @Thomas regarding Lupo Quote
I have found some documents related to your car:
1. Oil Leak
2. Loading System
3. Bad gas intake
1. Oil Leak
Cause: Occasionally, due to insufficient application of sealant, there can be oil leakage at the outer bearing cover and in the radii areas.
If a clear oil leak between the cylinder head and cylinder head is detected, proceed as follows:
- Remove external storage covers.
- Very important: Clean the printing surfaces, for example with spirit.
- Lightly apply sealant AMV 174 004 to the edges of the storage lid
extend
- Immediately install the pallet cover.
- After proper installation of the bearing covers, the following
Carefully remove the sealant. (The sealant can damage the cylinder)
(head/lid seal)
- Before removing the cylinder head cover, transitions from bearing cover/
Cylinder head and crescent-shaped cutout with D 454-300 A2 be-
erase.
Damage Number: 15 82 050
2. Loading System
The spring band clamp, which secures the pressure pipe to the turbocharger flange, is defective in some vehicles. This can cause the pressure pipe to loosen.
Install a new band clamp with part number: 1H0 145 917 A.
3. Bad gas intake
At high temperatures in the engine compartment, under unfavorable operating conditions, the brake booster may not function properly, resulting in insufficient pedal return.
Due to insufficient pedal depression, the brake light switch is not activated, and as a result, the engine is automatically shut down by the engine control unit (emergency mode).
In case of complaint, install a new brake booster.
ET-Nr. 6N1 614 106 C.
Damage Number: 47 70 010
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 6X1 MJ 2002: Clicking Noise Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts @ Tim 27 regarding pump tuning Diesel Engine Technology
No new posts Kulanz Costs: What You Need to Know Diesel Engine Technology
No new posts An OBD Profis wegen Tacho On-Board Diagnostics (OBD)
No new posts Translation Services: Get Accurate & Reliable Transla... Diesel Engine Technology
