Belt Replacement: How-To Guide & Tips
papatom
Post16-08-2002, 8:10    Subject: Belt Replacement: How-To Guide & Tips Quote
I'm planning to take my Passat to the workshop soon. Since I have the option of using the training workshop at DC, it should be relatively inexpensive (hopefully). I've already added the timing belt with tensioners to the list, as well as all the filters. Unfortunately, I don't know what's included in the service plan for a major inspection. Are there any other things I absolutely need to have done, such as the ribbed belt and the serpentine belt for the air conditioning (since they have to be removed anyway when changing the timing belt)?
Okay, one more thing, the Passat makes this rumbling (roaring) noise when taking left turns. At first, I thought it was a piece of metal that had come loose from the exhaust and was pressing against the shield, but that's gone now, and it's still rumbling. I suspect it might be a wheel bearing, but I'm not sure if it's the front or rear one, or if something else could be the cause.
Well, this certainly doesn't seem like a TDI issue. If this is the wrong forum for this, please let me know where else I can go.
THX papatom
Translated on 06-09-2026, 10:12.
Post16-08-2002, 9:07    Subject: Topic: [Dein Thema hier] Quote
Hi Papatom,
You are absolutely right...
...but there's a section called "Chassis, Body, and Interior" where that topic belongs.
Check out /viewtopic.php?t=789, that should address your problem.
Translated on 06-09-2026, 10:14.
papatom
Post16-08-2002, 9:54    Subject: Belt Replacement: How-To Guide & Tips Quote
Okay, icon_redface.gif so the issue with the wheel bearing is put on hold for now. I'll check it as described and get back to you if necessary.
The topic of belts, etc., is still open icon_sad.gif.
papatom
Post19-08-2002, 14:04    Subject: Belts: What's the deal? Quote
icon_sad.gif Just replace the timing belt, or should I also replace the ribbed belt and the V-belt for the air conditioning (they have to be removed anyway when changing the timing belt?). icon_rolleyes.gif icon_question.gif
Translated on 06-09-2026, 10:15.
DocSnydor
Post19-08-2002, 14:41    Subject: Belt Replacement: How-To Guide & Tips Quote
So, on my 35i 1Z, when the timing belt was changed, the pulleys and the serpentine belts were also replaced at the same time. This was done by VW themselves...
However, this is already the second timing belt replacement (the first one was at 180,000 km), and unfortunately, I don't have air conditioning.
Translated on 06-09-2026, 10:16.
To
Post16-06-2004, 19:14    Subject: Belt Replacement: How-To Guide & Tips Quote
My car's maintenance schedule indicates that the timing belt needs to be replaced next month. I'm currently considering whether to also have the serpentine belt (also known as a ribbed belt) replaced at the same time. Can anyone tell me approximately how much those two belts cost?
Should the valve cover gasket also be replaced?
Tobias.
Translated on 06-09-2026, 10:17.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post16-06-2004, 21:22    Subject: Belt Replacement: How-To Guide & Tips Quote
"In my opinion, the original V-ribbed belts are too expensive, costing between 50 and 100 euros."
Depending on the size, they don't cost more than 30 euros as accessories.
B.Eng (FH) u. KFZ Meister
wolfi_b
Post16-06-2004, 21:51    Subject: Belt Replacement: How-To Guide & Tips Quote
Okay, for my 1Z, the ribbed belt costs €15 and the V-belt costs €5. According to my manual, replacing the belts is not a mandatory service. And the ribbed belt should last the entire life of the car. So, I only replaced the V-belt (mainly because it was squeaking).
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 06-09-2026, 10:18.
mercy1960
Post16-06-2004, 23:00    Subject: Belt Replacement: How-To Guide & Tips Quote
hello
And the ribbed belt should last a car's entire lifetime. So, in my case, I only replaced the serpentine belt. (Mainly because it was squeaking)[/quote]
Unfortunately, he rarely does that.
Rib belts also become hard and brittle.
If they develop cracks on the inner side, near the ribs, they are worn out and should be replaced before they tear and the AC/DC unit needs to be serviced!
greetings
Translated on 06-09-2026, 10:19.
WarLord
Post17-06-2004, 9:27    Subject: Belt Replacement: How-To Guide Quote
Mileage: 110,000 km, not tuned
Wow, not bad.
Best regards, WarLord.
Translated on 06-09-2026, 10:20.
To
Post17-06-2004, 9:55    Subject: Belt Replacement: How-To Guide & Tips Quote
Thank you for your opinions. I will take a closer look at the straps (including the insides).
What are your thoughts on replacing the valve cover gasket?
Tobias.
Translated on 06-09-2026, 10:21.
dieter
Karma: +13 / -0   Thank you, like it!
Post17-06-2004, 12:32    Subject: Belt Replacement: How-To Guide & Tips Quote
What do you think about replacing the valve cover gasket?
If you don't want to preserve your engine with oil...
Yes, exchange them. Mine didn't seal properly again.
greetings
dieter
T3 syncro 16 AFN
To
Post09-07-2004, 19:26    Subject: Belt Replacement: How-To Guide & Tips Quote
Thank you for your advice. I took a closer look at the two belts, and they actually seem to be in quite good condition (including the inside). Well, I then discussed it with the mechanic, and since they have to be removed anyway, we decided to replace them with new ones. Today I picked up the car, and what did I find on the ribbed belt: a hand-applied direction of rotation marking...
Tobias.
Translated on 06-09-2026, 10:22.
garth.brooks
Post10-07-2004, 10:51    Subject: Valve Cover Gasket: Seal & Prevent Leaks Quote
Regarding valve cover gaskets:
After opening, it wouldn't seal properly again, and that thing is quite expensive. So, I took a closer look at the whole thing.
It's because the gasket compresses over time, but the valve cover can't be pressed too tightly onto the head due to the spacer sleeves. The solution: I placed a large, thick washer underneath to apply additional pressure to the rubber gaskets, bypassing the sleeves. It sealed again right away.
It doesn't cost anything, and if it doesn't work, you can always buy a new seal.
Cleanliness of the sealing surfaces and the gasket must always be ensured!
Translated on 06-09-2026, 10:23.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Timing Belt & Serpentine Belt Replacement - Audi A2 1Z Diesel Engine Technology
No new posts GIII AHU: Short Belt, No AC Compressor? Diesel Engine Technology
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts How Often to Change Filters? Diesel Engine Technology
