hemig Blaumann
25-05-2004, 16:59 Subject: AXR Whistle: Does it Whistle at Idle? |
in der Suche habe ich speziell zum AXR-Motor nichts gefunden. Ich dachte immer TDIs pfeifen erst wenn der Turbo einsetzt. Bei meinem Golf (AXR) pfeift es schon im Leerlauf recht laut. Is this normal?
Greetings from Wiesbaden.
Holger.
Translated on 02-09-2026, 11:49.
Bertil Profi-Schrauber
26-05-2004, 20:49 Subject: AXR Whistle: Does it Whistle at Idle? |
"There's no whistling sound coming from my AXR when it's idling."
There might be a leak somewhere in the speaker area. In my case, it was caused by the LLK (likely referring to a specific component).
hemig Blaumann
26-05-2004, 20:52 Subject: AXR Whistle: Does it Whistle at Idle? |
Hello Bertil,
Thank you for the response. Does your engine actually whistle? The workshop said the whistling is normal. The performance seems normal, but if there's a leak, the performance should be lower.
Holger.
Translated on 02-09-2026, 11:50.
26-05-2004, 20:56 Subject: AXR Whistle: Does it Whistle at Idle? |
hemig wrote: | Does your engine even whistle? The workshop said that the whistling is normal.
Yes, under load, when the turbo is working correctly, it makes a slight whistling sound.
Quote: |
The performance seems normal; if there were a leak, the performance should be lower.
Not necessarily.
Jan6K and I both had a leaky LLK (low-pressure cooling system), but mine didn't cost any performance (I think Jan's also didn't, but he just noticed it).
I'll try to find the post... it might take a while.
EDIT ... found
/viewtopic.php?t=3595&highlight=llk+leak
Translated on 02-09-2026, 11:51.
26-05-2004, 21:34 Subject: AXR Whistle: Does it Whistle at Idle? |
Yep, in my case, the leaking coolant only caused a loud whistling sound around 2000 RPM and increased smoke development. The performance was still fully there.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 02-09-2026, 11:52.
hemig Blaumann
26-05-2004, 21:45 Subject: AXR Whistle: Does it Whistle at Idle? |
Okay, when I got the car, the plastic trim on the right front fender was partially torn off. I think the noise must be coming from near the power steering cooler. I'll take a look under the trim that the workshop has since attached tomorrow. The whistling should be coming from near the leak. Let's see if it gets louder when I remove the trim. I'm already monitoring the oil consumption because I just got the car.
Holger.
Translated on 02-09-2026, 11:53.
27-05-2004, 8:36 Subject: AXR Whistle: Does it Whistle at Idle? |
Hello Holger,
hemig wrote: | ...
aha, when I got the car, the trim on the right, front fender was partially torn off... |
Okay, so this is the most sensitive part of the G4.
The standard LLK (likely referring to a specific type of container or equipment) is very fragile. I just sat on a pile of snow, and it was already leaking. Unfortunately, you couldn't see the leak.
Translated on 02-09-2026, 11:55.
hemig Blaumann
29-05-2004, 8:00 Subject: AXR Whistle: Does it Whistle at Idle? |
Okay, so I went to a different dealer this time. It was VW Klein in Sossenheim. Has anyone had any experience with that place? I was very satisfied. The master technician spent over an hour with me trying to locate the problem. It seems there was a modified pipe related to the AGR system that wasn't installed in my car. It's now been ordered and will be installed on Tuesday.
There was nothing on the LLK (likely referring to a specific part of a machine), and I examined it carefully on the stage. I didn't see any oil leaks, and everything looked perfectly clean.
I'm curious to see if the problem will be fixed by Tuesday.
Holger.
Translated on 02-09-2026, 11:56.
hemig Blaumann
02-06-2004, 5:37 Subject: AXR Whistle: Does it Whistle at Idle? |
Hello again,
I picked up the Golf from the workshop yesterday. The whistling noise is still there even after they replaced the pipe. Today, I'm getting a new turbocharger... I'm curious to see what happens.
Holger.
Translated on 02-09-2026, 11:57.
02-06-2004, 8:32 Subject: AXR Whistle: Does it Whistle at Idle? |
hemig wrote: | Today I'm getting a new turbocharger... I'm curious to see how it performs.
WHAT???
If you have too much money, feel free to give it to me!
Why a new turbo? Who's going to pay for it? Do you know how much it costs?
*surprised*
Translated on 02-09-2026, 11:58.
Profile PM Garage |
hemig Blaumann
02-06-2004, 18:09 Subject: AXR Whistle: Does it Whistle at Idle? |
The Golf is still under warranty, of course. It's one of the last models that came off the production line (Pacific).
The turbo wasn't it  . Tomorrow, the exhaust pipe and the catalytic converter will be checked. But that whistling is really annoying. It's very loud and clear when idling.
Holger.
Translated on 02-09-2026, 11:59.
joergs Guest
02-06-2004, 18:37 Subject: AXR Whistle: Does it Whistle at Idle? |
Are we now seeing a period of chaotic and unpredictable changes because we're not really sure what to do next?
hemig Blaumann
02-06-2004, 19:02 Subject: AXR Whistle: Does it Whistle at Idle? |
It seems like (a sex change frenzy).
I'm also not sure what it could be (training and studies in automotive technology). The coolant seems to be leaking. I would have thought it was most likely the turbo. I can't really imagine it being the catalytic converter. Since it was once a rental car, I'm actually quite happy with the new turbo. The vehicle was very cheap, but it was probably rarely driven when fully warmed up.
I'm not sure if there's a pre-pump or something like that in the PD engines, and if so, where it's located in the Golf. It could certainly be something like that. Let's see. The service at my workshop is definitely great, even though I didn't buy the car there.
Holger.
Translated on 02-09-2026, 12:00.
bloeckler
02-06-2004, 19:59 Subject: AXR Whistle: Does it Whistle at Idle? |
My ATD also whistles slightly at idle. It has full power, doesn't smoke, and doesn't sound unhealthy.
Translated on 02-09-2026, 12:01.
02-06-2004, 20:35 Subject: AXR Whistle: Does it Whistle at Idle? |
Yes.
PDs have a pre-feed pump, but where is it located?
Translated on 02-09-2026, 12:02.
Profile PM Garage |
03-06-2004, 15:40 Subject: AXR Whistle: Does it Whistle at Idle? |
dieselmartin wrote: | | PDs have a pre-feed pump, but where is it located???? |
Submersible pump in the tank  .
Profile PM Garage |
