Golf 3 TDI won't start: Troubleshooting guide
momolea
Post01-07-2004, 21:15    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
icon_sad.gif Hello,
My Golf 3 TDI with 90 horsepower, manufactured in October 1996, won't start anymore!
'The engine is turning, but the preheating indicator light is not illuminating fully. I have already replaced the ignition switch, but without success. The second key also doesn't work. This error has occurred multiple times: after repeatedly turning the ignition key, the car eventually started.'
Now, it won't start.
Perhaps someone can help me?
Translated on 30-10-2026, 14:16.
Post01-07-2004, 21:57    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
The preheating indicator light is not illuminating fully,
The TDI no longer has a "glow plug check light."
The glow spiral is essentially just a motor information light.
When you turn the ignition on, the lights come on briefly and then go off again.
What do you mean by "not fully" illuminating?
Translated on 30-10-2026, 14:18.
Mulag_md5
Post01-07-2004, 22:21    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
It could be any of those things right now. A defect in the WFS (water flow sensor) is likely. It could also be a worn crankshaft. The boss says running a diagnostic test will provide clarity.
Best regards, Holger.
Translated on 30-10-2026, 14:19.
momolea
Post02-07-2004, 5:39    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
The filament is not glowing at full brightness; if the error hadn't occurred, the lamp would have been 'normally bright,' but now it's 'glowing dimly.'
Tom.
momolea
Post02-07-2004, 5:41    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
I'll try using relay 109.
Post02-07-2004, 7:37    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
icon_idea.gif Good idea, chance of success ~ 95%.
Translated on 30-10-2026, 14:20.
momolea
Post02-07-2004, 20:05    Subject: Golf 3 TDI won't start: Troubleshooting guide Quote
icon_biggrin.gif The miracle relay is installed, and now the car is working again.
Thank you very much icon_wink.gif.
kleffx
Post22-07-2004, 22:27    Subject: Same Problem, Same Cause: Find the Solution Quote
Report:
My Golf III GT TDI suddenly stopped starting one day.
There was voltage, the starter motor was running, but the engine wouldn't start like it usually does after 3-4 attempts. I then tried starting it for longer periods several times - without success.
Then I noticed that the preheating indicator light wasn't coming on at all (not even briefly, as it usually does). I remembered the preheating fuse in the engine compartment from my old Golf I GTD days. I checked it with a multimeter - it showed continuity, so everything seemed okay.
That's when I reached the end of my knowledge. I had already pictured having the car towed to the workshop in my mind – until I had the idea to search the internet. I had already found a lot of things for my motorcycle (Africa Twin), such as a workshop manual for download – so why not find something similar for the car too?!
While searching on Google, I quickly came across this top-rated board. With patience, using the board search function and constantly refining my search queries, I repeatedly found references to "Relais 109." The rest, as they say, is history.
I disassembled and opened it - visually everything looks okay, no cold solder joints are visible, and everything else seems to be in perfect condition. Since I didn't have any other ideas, I still ordered a replacement: 11.37 euros including VAT. I installed it, preheated it, and *whoosh* - the engine is running like new.
So, a big thank you to everyone who writes and helps here, and especially to the forum administrators.
I'll definitely be coming here more often now...
Hello kleffx.
Translated on 30-10-2026, 14:22.
Post23-07-2004, 6:41    Subject: Similar Issue: Same Cause Quote
kleffx wrote:
With a calm approach, using the board's search function and constantly entering new search queries, I repeatedly found references to relay 109. The rest, you can imagine.
So, thank you very much to everyone who writes and helps here, and especially to the forum administrators.
Thank you - it's also nice to read something like that again icon_rolleyes.gif.
I'll add to the story about the frequent errors -> the preheating indicator light might be dimmer, etc.
Translated on 30-10-2026, 14:25.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf III TDI won't start? Troubleshooting. Diesel Engine Technology
No new posts Golf 3 TDI: Won't Start? Troubleshooting Guide Diesel Engine Technology
No new posts Golf III TDI: Won't Start? Troubleshooting Guide Diesel Engine Technology
No new posts VW Golf 3: Won't Start? Troubleshooting Guide. Diesel Engine Technology
