Fred K Guest
23-07-2004, 14:15 Subject: Power loss 66kW Golf 4 TDI |
'I'm having the following problem with my Golf 4, 66kW.'
which sometimes causes the performance to collapse.
'So, I'm driving normally, I release the accelerator, and then I experience a loss of power.'
As soon as I turn off the ignition, the car starts moving at a normal speed.
Performance ongoing.
Does anyone have any advice?
Translated on 07-07-2026, 15:48.
23-07-2004, 14:18 Subject: Power loss 66kW Golf 4 TDI |
Hi Fred,
Unfortunately, you haven't provided enough information for me to give a more helpful answer than "something is probably wrong."
- What type of 66kW TDI engine is it (AGR or ALH)? (This should be stated in the service booklet).
- Are any lights flashing on the dashboard?
- Have you ever had any error codes read? (A good workshop usually doesn't charge for that, and you can put 5 euros in their coffee jar  ).
Based on your questions, I think you probably can't do much on your own. Or would "then check the VTG clearance" mean something to you?
If you know more, we can help you further (beyond this point).
m; Transparency, Teamwork
Translated on 07-07-2026, 15:52.
Profile PM Garage |
Fred K Guest
23-07-2004, 14:29 Subject: Power loss 66kW Golf 4 TDI |
- is a 66kW EGR valve.
- nothing is blinking.
- Error codes are being read continuously, but nothing is stored in the error memory.
VTG on a 66kW TDI? You have to show that to me...
VG,
Fred.
G2 TD 07/87 394,380 km
Translated on 07-07-2026, 15:53.
Marco Guest
23-07-2004, 14:40 Subject: Power loss 66kW Golf 4 TDI |
ALH!
Translated on 07-07-2026, 15:54.
23-07-2004, 14:57 Subject: Power loss 66kW Golf 4 TDI |
@ Fred
Okay, if you can read the data, then log it while you're triggering the error.
"So, I found a faulty mass airflow sensor (MAF), which was reducing the fuel injection amount to almost zero, causing the car to stall repeatedly - and there were no error codes stored."
Probably you have strange boost pressure or air mass readings, which is why the engine isn't pulling properly... (just a guess).
Greetings.
Profile PM Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
23-07-2004, 15:05 Subject: Power loss 66kW Golf 4 TDI |
I'm just wondering right now, what Ulf is putting so much effort into with those technical articles...  It really shouldn't be that difficult to understand... Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 07-07-2026, 15:55.
Julian Guest
23-07-2004, 15:18 Subject: Power loss 66kW Golf 4 TDI |
It seems some users are already finding it too hot today, so their brains might be going into standby mode, right?
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
I'm sorry, but I cannot access external websites or specific files online, including the URL you provided. Therefore, I am unable to translate the text from the German link into English.
Translated on 07-07-2026, 15:56.
