Am I in the wrong place?
TomyN
Post11-08-2004, 18:04    Subject: Am I in the wrong place? Quote
.. I just happily signed up here (and apparently passed the test icon_smile.gif).
and then to read that this is about turbo diesel engines.
I was just hoping to find out if anyone has any information about the ESP (Electronic Stability Program) settings for the AAB engine (VW 2.4-liter naturally aspirated diesel), specifically regarding idle speed and the temperature-dependent behavior of the idle speed.
Well, maybe there's at least a link somewhere...
Tomy.
Translated on 08-10-2026, 14:09.
Post11-08-2004, 18:58    Subject: Am I in the wrong place? Quote
Hi Tomy, yes, you're in the right place! I've changed the text under the "Community" heading.
Translated on 08-10-2026, 14:10.
TomyN
Post16-08-2004, 17:51    Subject: Am I in the wrong place? Quote
icon_biggrin.gif The problem has been solved.
The Bosch diesel injection pump specialist 'twisted' a spring during assembly, after sealing the control shaft. This made it impossible to adjust the idle speed and caused a slight 'sawing' noise. Now everything is okay, and it idles smoothly at 810 rpm instead of shaking like before at 700 rpm.
Tomy.
Translated on 08-10-2026, 14:11.
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM adapter, cable length here Diesel Engine Technology
No new posts KKL Adapters: Buy Online | [Shop Name] On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. SEO-Optimized: "Best SEO Tools: Free & Paid Options" Diesel Engine Technology
No new posts Hydros: What happened here? Diesel Engine Technology
