VW 1.6 TDI: Long Preheat Time Explained
mueller900
Post11-11-2004, 22:05    Subject: VW 1.6 TDI: Long Preheat Time Explained Quote
I have a 1986 model with a 1.6 liter diesel engine.
My preheating indicator light turns off after about 1 minute.
I have to pre-heat it for at least 20-30 seconds before it starts without needing to crank it too much.
Has anyone had experience with weaknesses or vulnerabilities (such as corrosion)?
Translated on 12-10-2026, 13:01.
Post11-11-2004, 23:39    Subject: VW 1.6 TDI: Long Preheat Time Explained Quote
The vulnerability is a broken temperature sensor line.
If the relay does not receive temperature information, it will remain illuminated indefinitely.
You have two temperature sensors, one for the display and one for the heating element.
The cables are white/blue and yellow/red.
Just tap it briefly; once to display the information about "Heiss," and once to immediately stop the heating.
If not, it's probably a broken cable.
If so, a sensor might be broken.
Translated on 12-10-2026, 13:02.
No new posts Probleme mit Vorglühen Diesel Engine Technology
No new posts No preheating required in sub-zero temperatures On-Board Diagnostics (OBD)
No new posts Minimum idle speed during cold start WITH preheating Diesel Engine Technology
No new posts Vorglühen über Türkontakt beim TD (AAZ) Diesel Engine Technology
