Tacho Software: Erfahrungen & Reviews
Go to page: 1, 2, 3  Next
meyert
Post23-04-2003, 9:07    Subject: Tacho Software: Erfahrungen & Reviews Quote
'I jokingly bought some software for speedometer adjustment via OBD from *bay. The program is called alfa8.exe and, of course, it doesn't work. The program claims to be examining the instrument cluster and then closes itself. However, you can hear the relay clicking in the dashboard, just like with VAGCOM, which works perfectly with my interface. What's strange is that after a while after the program starts, a printer error message appears. It's almost as if the program is trying to access the parallel port, like some EEPROM programmers do for direct instrument cluster adjustment.'
Does anyone have experience with this?
T M
Translated on 01-09-2026, 19:11.
kenny
Post23-04-2003, 10:24    Subject: Tacho Software: Erfahrungen & Reviews Quote
Okay, let's start by seeing what kind of data it's sending to the interface...
Translated on 01-09-2026, 19:12.
meyert
Post23-04-2003, 10:37    Subject: How to... Quote
Hello Kenny,
Do you know of any tools or tricks that can be used to monitor or intercept data on Windows/DOS? I might be able to think of something for Unix...
T M
joergs
Post23-04-2003, 10:51    Subject: Tacho Software: Erfahrungen & Reviews Quote
I'm also familiar with alfa8. However, I don't have it from that platform. When I connect it, it correctly reads the version of the instrument cluster, and that's it. Then, depending on what's being displayed, it shows 'Please wait a moment...' for hours! Well, either something isn't compatible, or my speedometer is too new, or this program is simply useless!
Translated on 01-09-2026, 19:13.
meyert
Post23-04-2003, 11:28    Subject: At least a little more... Quote
Hello Jörgs,
What kind of vehicle do you have?
TM
Translated on 01-09-2026, 19:14.
joergs
Post23-04-2003, 11:31    Subject: Tacho Software: Erfahrungen & Reviews Quote
Passat 3BG, year of manufacture 2001, engine code AWX.
mozz
Post23-04-2003, 15:46    Subject: Tacho Software: Erfahrungen & Reviews Quote
Hmmm...
I, just for fun, obtained some software for speedometer adjustment via OBD from *bay. The program is called alfa8.exe and, of course, it doesn't work. The program claims to be examining the instrument cluster and then closes itself.
I'm going to ask a really dumb question: how did you start the program?? under Windows??? try running it under DOS icon_wink.gif.
then it definitely won't shut down immediately! it should recognize your combination instrument + immobilizer. then it should say "enter new value:" - then you enter something and press enter, it ticks a bit, well, and only then does the program crash icon_redface.gif with a squeaking system speaker!
Sure, here's the translation:
"Hello, Mozz."
PS: If you want, send me yours, I'll send you mine, and let's see what symptoms appear. I suspect it might also be important which notebook model is being used!
Translated on 01-09-2026, 19:15.
meyert
Post23-04-2003, 19:02    Subject: Proggi: Doesn't Run on DOS - Troubleshooting Guide Quote
Hello Mozz,
Of course, I also tried it under DOS. I booted from DOS 6.2 and DOS 7.0 from floppy disk. Starting Alfa8 results in the same effect as under Windows, except that the window cannot be closed. Instead, you get a blank screen with a c:\ prompt.
TM
Translated on 01-09-2026, 19:17.
mozz
Post23-04-2003, 22:57    Subject: Tacho Software: Erfahrungen & Reviews Quote
SORRY! But sometimes things happen to me, and when you say it might close again, I assume the worst!
"gruzz" is a German slang term that can be translated as "greetings" or "regards." It is often used in informal settings, such as text messages or social media posts.
Karma: +807 / -0   Thank you, like it!
Post28-04-2003, 17:18    Subject: Tacho Software: Erfahrungen & Reviews Quote
Translated on 01-09-2026, 19:18.
joergs
Post28-04-2003, 17:26    Subject: Tacho Software: Erfahrungen & Reviews Quote
hi rainer,
This is the first thing that runs for me with unfamiliar software! icon_razz.gif
kenny
Post28-04-2003, 17:29    Subject: Tacho Software: Erfahrungen & Reviews Quote
You don't even need a virus if you can get people to run a foreign program. Then you can already do whatever you want! So, antivirus software isn't very helpful in that case...
Translated on 01-09-2026, 19:19.
Mc_Givertechnik
2010 Volkswagen T5
Post28-04-2003, 19:01    Subject: Tacho Software: Erfahrungen & Reviews Quote
Hey everyone!
Is there anyone among you who has had success with alpha8??? icon_confused.gif Or does anyone know of an alternative??? icon_smile.gif
Since I'm still driving around with a speedometer that has an incorrect mileage reading, it will soon be time for me to find a solution icon_confused.gif.
Has anyone had success with "removing the memory battery from the instrument cluster"?
Greetings to you all.
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
joergs
Post28-04-2003, 19:17    Subject: Tacho Software: Erfahrungen & Reviews Quote
What is the purpose of expanding the battery? The data is stored in an EEPROM or Flash memory. You can disconnect the battery for weeks or even years, and nothing will happen!
Translated on 01-09-2026, 19:20.
Mc_Givertechnik
2010 Volkswagen T5
Post29-04-2003, 5:21    Subject: Tacho Software: Erfahrungen & Reviews Quote
Hey joergs!
Okay, good argument, I understand. But how do I approach this problem now? icon_cry.gif Vau Weh told me that they read the old odometer data from the original instrument and "write" it back into the new one. icon_eek.gif But how do they do that? So, there must be something at Vau Weh that allows changing the odometer reading via OBD II. I don't want to do anything illegal; I just want to increase the odometer reading to the correct value. icon_redface.gif
Thank you for your information.
Peter.
Translated on 01-09-2026, 19:21.
PrivatBereich
Post29-04-2003, 8:49    Subject: Tacho Software: Erfahrungen & Reviews Quote
Hello Peter,
Why are you so sure that VW can change the mileage reading via ODB-II? icon_question.gif I would guess that they have no interest in doing that; they would rather sell a new one, where the mileage can be easily changed... icon_evil.gif
As far as I know, a kilometer correction on used speedometers is only possible when the speedometer is removed and accessed through the socket on the back. icon_mad.gif I tend to believe everything only when I've seen it or tried it myself. icon_eek.gif After all, a lot is claimed on eBay & Co., especially when the day is long. icon_idea.gif
Private.
Translated on 01-09-2026, 19:22.
No new posts Modified Engine Noise After Nozzle Replacement (Experienc... Technical Articles
No new posts MTM Chip in AJM. Who has experience? Diesel Engine Technology
No new posts AGR System Decommissioning: Experiences? Diesel Engine Technology
No new posts Experience: Differences between 1Z and AHU Diesel Engine Technology
No new posts SDI: 10 Cent Experience and Review Diesel Engine Technology
