Bleeding Clutch Hydraulic System (02-06-2004, 8:04)
wolfi_b
Post02-06-2004, 8:04    Subject: Bleeding Clutch Hydraulic System Quote
Hello!
"I'm having problems with the clutch hydraulics on my B4 TDI 1Z, manufactured in 02/93. It seems like air is accumulating in the lines and cylinders after some time. When the engine is cold, there's a lot of jerking when starting."
I've also bled the clutch multiple times, which provides relief for 1-2 months. However, I haven't been able to find any leaks – brake fluid isn't leaking anywhere. But if brake fluid isn't leaking anywhere, then air can't be getting in anywhere, or icon_question.gif
I hope someone can give me some advice.
Best regards, Wolfi.
Translated on 19-09-2026, 6:40.
joergs
Post02-06-2004, 8:26    Subject: Bleeding Clutch Hydraulic System Quote
Have you bled the master and slave cylinders?
How did you bleed the brakes? Did you use a hose connected between the brake caliper and the master cylinder? Or did a workshop use a pressure-generating device on the brake fluid reservoir to do it?
Translated on 19-09-2026, 6:41.
wolfi_b
Post02-06-2004, 9:16    Subject: Bleeding Clutch Hydraulic System Quote
Yes, that's exactly what I did – I used a hose between the brake caliper and the slave cylinder. It was a bit of a makeshift solution, but it worked for a while.
According to my understanding, is the donor and receiver cylinder bled during this process, or not?
Translated on 19-09-2026, 6:42.
joergs
Post02-06-2004, 9:33    Subject: Bleeding Clutch Hydraulic System Quote
No! You have to bleed the two cylinders separately. However, the master cylinder can be bled this way, without using that complicated mechanism. But this bleeding method isn't precise. There's still a chance that a small amount of air could remain in the system.
wolfi_b
Post02-06-2004, 12:47    Subject: Bleeding Clutch Hydraulic System Quote
Yes, but if a small amount remains, that doesn't explain why the clutch then worked for 2 months...
Translated on 19-09-2026, 6:43.
Albrecht
Post02-06-2004, 17:27    Subject: Bleeding Clutch Hydraulic System Quote
The brake fluid level in the reservoir should always be kept above the connection point for the clutch. I have already experienced this phenomenon twice, where the clutch pedal completely collapsed due to a low fluid level (but not below the minimum). Workshops often like to sell a completely new clutch in such cases icon_twisted.gif.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
wolfi_b
Post26-06-2004, 0:49    Subject: Bleeding Clutch Hydraulic System Quote
Hello everyone!
Unfortunately, my problem is starting again icon_confused.gif.
@AlbrechtViewing profile: Albrecht
The brake fluid level was definitely not the problem.
For troubleshooting:
I'm going to try replacing the bleed valve now.
@joergs
Here's the translation:
"How precise is the procedure for bleeding the brakes? Building up pressure on the brake fluid reservoir wouldn't be a problem; I could probably rig something up."
BUT:
Since the lower connections of the two cylinders are connected, wouldn't I need to bleed the system in both directions?
"Or would the flow of liquid be sufficient to draw in air if I create an opening in the brake fluid reservoir?"
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 19-09-2026, 6:45.
wolfi_b
Post28-06-2004, 7:25    Subject: Bleeding Clutch Hydraulic System Quote
Hello - where are the professional mechanics?
Can anyone tell me the procedure for bleeding the clutch using a pressure bleeding device connected to the brake fluid reservoir?
Do I need to vent it in both directions?
1993 Audi 80 B4 1Z
Translated on 19-09-2026, 6:46.
joergs
Post28-06-2004, 8:15    Subject: Bleeding Clutch Hydraulic System Quote
I can't really say much about it, but I'll read up on it, maybe I'll find something. I haven't encountered that problem before... but I'll check it out tonight!
joergs
Post28-06-2004, 19:41    Subject: Bleeding Clutch Hydraulic System Quote
hello wolfi_b,
In the standard 'midnight screws' books, there's nothing detailed about it. Besides a mention of workshop work and specialized tools, they don't go into any further detail. Maybe someone has access to the Elsa documentation and can provide you with more information.
Sorry!
Translated on 19-09-2026, 6:47.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post28-06-2004, 19:58    Subject: Bleeding Clutch Hydraulic System Quote
Are people already failing to bleed the clutch here? icon_lol.gif icon_lol.gif
Bleeding is only performed at the slave cylinder on the transmission.
Connect the device to the BFK pressure vessel. Apply a pressure of approximately 1-2 bar.
"Open the valve on the cylinder after approximately 20-60 seconds (you may need to move the pedal back and forth a few times). Then, close the valve. Usually, bleeding the system doesn't do anything because the clutch system is self-bleeding as long as it's working properly."
In 90% of clutch failures, the master cylinder located at the pedal is defective.
Most often, the problem occurs when the pedal sinks forward and doesn't return to its original position. Bleeding the system can help, but usually only for a short time.
MFG Farni.
B.Eng (FH) u. KFZ Meister
Translated on 19-09-2026, 6:48.
wolfi_b
Post29-06-2004, 7:16    Subject: Bleeding Clutch Hydraulic System Quote
Yes, I've been waiting for this!
Thank you very much icon_biggrin.gif.
1993 Audi 80 B4 1Z
Translated on 19-09-2026, 6:49.
wolfi_b
Post30-06-2004, 7:54    Subject: Bleeding Clutch Hydraulic System Quote
Hello everyone!
Yesterday, I went to the mechanic and wanted to buy a distributor shaft. However, it costs 150€, and there's no gasket set available, so I decided not to buy it icon_confused.gif (Besides, I don't even know if it's really the problem).
What kind of seals are installed there? I hope I can find replacements somewhere and simply replace them.
Has anyone ever done this before?
1993 Audi 80 B4 1Z
Translated on 19-09-2026, 6:50.
wolfi_b
Post06-09-2004, 9:13    Subject: Bleeding Clutch Hydraulic System Quote
Okay, so it finally happened: this weekend I installed a new clutch. It was a lot of work, but it was worth it.
The clutch is working wonderfully icon_biggrin.gif, it's easy to depress, offers good control, and doesn't jerk at all anymore. Apparently, it wasn't the hydraulics after all.
However, I'm still wondering about the root cause because there's no visible defect on the old clutch. It's possible that the torsion springs were to blame, as they can be easily twisted by hand. Apparently, the preload has decreased.
Well, I hope this stays like this and the plucking doesn't start again.icon_cool.gif
1993 Audi 80 B4 1Z
Translated on 19-09-2026, 6:51.
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Bleeding Clutch Hydraulic System Diesel Engine Technology
No new posts The Path of the Air. Diesel Engine Technology
No new posts Remove soot with cold air?! Diesel Engine Technology
No new posts LMM: Too much air? Diesel Engine Technology
