Pop-off Valve: Usefulness and Purpose
Georg_G
2012 Volkswagen Golf
Post26-08-2004, 18:34    Subject: Pop-off Valve: Usefulness and Purpose Quote
I somehow recall that there was a discussion before about the usefulness or lack thereof of pop-off valves. I can't find that thread using the search function icon_sad.gif.
Perhaps it hasn't been fully explored yet.
Okay, let's start with the terminology: I'm envisioning installing a valve in the charge air duct. This valve should release "excessive pressure" so quickly that the control system of the variable turbine geometry (VTG) doesn't even need to adjust the guide vanes to minimize pressure buildup.
Is that the function of a pressure relief valve?
Normally, with increased boost pressure and increased fuel injection, you experience such strong pressure surges that the VTG (variable turbine geometry) control system initially produces "undershoots," and it takes almost 5 seconds to maintain a constant boost pressure.
My boost pressure has been increased to 1.1 bar using a diode solution.
If one were to install a valve that opens at 1.2 bar, wouldn't that valve then:
1) Reduce pressure peaks, thereby minimizing axial torque on the impeller shaft (leading to a longer lifespan).
2) Can the control loop of the VTG (Variable Turbine Geometry) reach the holding pressure of 1.1 bar more quickly?
Thank you for your responses.
Georg G.[/b]
Translated on 25-10-2026, 21:48.
christians
Post26-08-2004, 18:51    Subject: Pop-off Valve: Usefulness and Purpose Quote
Pop-off valves, in gasoline engines which have a throttle valve, are designed to maintain the airflow and thus the turbocharger's speed even when the throttle is briefly released, so that power can be quickly restored when the throttle is opened again.
While adjusting the timing might help with over-revving, there's a risk that it could significantly increase soot emissions and cause the turbocharger to fail due to excessive speeds.
Gruß Christian
Translated on 25-10-2026, 21:50.
Georg_G
Post28-08-2004, 13:55    Subject: Pop-off Valve: Usefulness and Purpose Quote
Hello Christian,
Okay... Then "Pop-Off" is probably the name of a different construction site icon_smile.gif.
How exactly does maintaining the mass airflow work? Is pressure from the intercooler system applied to the turbine's intake side to keep it at a certain speed (since the exhaust gases are no longer present when the throttle is closed)?
Thank you for the responses.
Georg.
Translated on 25-10-2026, 21:51.
christians
Post28-08-2004, 20:04    Subject: Pop-off Valve: Usefulness and Purpose Quote
At Audi, the air is circulated as standard. However, some people convert it to exhaust air circulation due to the noise.
Translated on 25-10-2026, 21:52.
WarLord
Post29-08-2004, 17:14    Subject: Pop-off Valve: Usefulness and Purpose Quote
@Georg_G
It's essentially about preventing the turbocharger from being braked too aggressively (i.e., slamming into a wall). Now, imagine that during a gear change, the throttle suddenly closes (of course, no power is needed at that moment). The turbocharger would slam into a wall and be braked abruptly. This isn't particularly good for its lifespan. However, if you release the pressure, the turbocharger can gradually spool down (like in a TDI engine). After the gear change, the turbocharger can quickly return to its operating speed and provide boost again.
Best regards, WarLord.
Translated on 25-10-2026, 21:53.
Georg_G
Post31-08-2004, 12:28    Subject: Pop-off Valve: Usefulness and Purpose Quote
Hello Warlord.
Thank you for the explanation; now I can understand it a little better.
Georg.
Translated on 25-10-2026, 21:54.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Turbo Boost Increase for AKN Engine: Info Diesel Engine Technology
No new posts AGR Valve Check: Diagnosis and Control Diesel Engine Technology
No new posts Question: Info on CAN-Bus Interface RKS+CAN variants On-Board Diagnostics (OBD)
No new posts What is the purpose of TDI tuning roller measurements? Diesel Engine Technology
