Fuel Injector Cleaning: Improve Performance
g1om
Post31-08-2004, 17:46    Subject: Fuel Injector Cleaning: Improve Performance Quote
hi everyone,
I have a question regarding experiences with refurbished fuel injectors.
Last week, I took my fuel injectors to the Bosch service center for an overhaul after they had been in use for 160,000 km. They found that the injection pressure was 180 bar (the target is 190 bar) and offered to readjust the injectors, which I then had them do.
Since the injectors were reinstalled, I can no longer reach the maximum speed.
'Now, I'm using about 1 liter more fuel every 100 kilometers.'
The demand for nail services has increased significantly.
I've also tried centering the fuel injectors in their guides on the cylinder head, but it didn't reduce the noise.
Can the guys at Bosch actually calibrate two-stage injectors?
Is it possible that the injection pressure of the second stage is not correct, since they can only check and adjust the first stage?
P.S. He finally passed the exam, he doesn't smoke anymore icon_biggrin.gif, but he also doesn't have much energy anymore icon_cry.gif icon_cry.gif.
Translated on 22-09-2026, 19:18.
Post31-08-2004, 17:53    Subject: Fuel Injector Cleaning: Improve Performance Quote
Does the needle lifter still work?
Translated on 22-09-2026, 19:20.
g1om
Post31-08-2004, 19:01    Subject: Fuel Injector Cleaning: Improve Performance Quote
I think so, I've only ever used a screwdriver on it once. I think it's still working.
To what extent can I examine this device more closely?
Would you recommend that I make some new ones?
joergs
Post31-08-2004, 19:38    Subject: Fuel Injector Cleaning: Improve Performance Quote
What does the error memory say?
Are the IMM values okay?
Is the print quality okay?
Have you read any technical articles on troubleshooting performance issues?
Translated on 22-09-2026, 19:21.
g1om
Post02-09-2004, 20:15    Subject: Fuel Injector Cleaning: Improve Performance Quote
Yes, everything is fine.
Furthermore, the acceleration before the overhaul was significantly better.
Shouldn't I just put some new ones in?
At Seat, however, they can be really expensive!
'Or, do you have any good tips on which injectors would provide a bit more power without damaging the pistons?'
joergs
Post02-09-2004, 20:32    Subject: Fuel Injector Cleaning: Improve Performance Quote
stop:
Have you checked and possibly corrected the fuel injection timing after installing the refurbished injectors?
Translated on 22-09-2026, 19:22.
g1om
Post04-09-2004, 14:06    Subject: Fuel Injector Cleaning: Improve Performance Quote
Yes, I did, but it only changed very slightly.
Post04-09-2004, 14:37    Subject: Fuel Injector Cleaning: Improve Performance Quote
Well... it would be almost too good to be true... Cleaning carboned-up injectors might be useful, but it won't make worn-out injectors new again.
If your engine is worn out, washing it won't (unfortunately) make it like new again.
We now offer new nozzle inserts and refurbishment services in our shop.
http://shop.dieselschrauber.de/index.php/cPath/36
Translated on 22-09-2026, 19:23.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post04-09-2004, 16:56    Subject: Fuel Injector Cleaning: Improve Performance Quote
Was wurde bei dir nur korrigiert, der Öffnungsdruck oder...?
Did they also replace the injector nozzles at the same time?
B.Eng (FH) u. KFZ Meister
g1om
Post05-09-2004, 20:38    Subject: Fuel Injector Cleaning: Improve Performance Quote
Only the opening pressure was corrected!
I also occasionally get an error code stored in the system.
'Maybe the problem isn't the injectors, but the pump itself; perhaps it's not generating enough pressure.'
Translated on 22-09-2026, 19:24.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Oversteering Issues: 3C5 CBAB Model Analysis Diesel Engine Technology
No new posts TDI Injectors: AFN to 1Z Conversion Guide Diesel Engine Technology
No new posts AEL Injectors: Replacement & Performance Parts Diesel Engine Technology
