Power Relay 1Z: Reliable & Efficient
MichaB.
Post11-09-2004, 12:09    Subject: Power Relay 1Z: Reliable & Efficient Quote
hi,
While searching for the cause of my starting problem, the following possibility cannot be ruled out:
Since the car often doesn't start again immediately after being turned off, it's possible that the aforementioned relay is defective. Unfortunately, I don't know where this relay is located in my car or what its part number is... Can anyone help me with that?
'Where is the power supply relay for the engine/control unit located in a Volkswagen Golf 3?'
Hi Micha,
Translated on 06-09-2026, 8:28.
Hati
Post11-09-2004, 12:35    Subject: Power Relay 1Z: Reliable & Efficient Quote
Relay 109 is located on the left side, below the steering wheel and above the fuses, in a socket. It should also have the number 109 printed on it. Therefore, it should be easy to find, even if I have found it before icon_biggrin.gif.
Heart.
Translated on 06-09-2026, 8:29.
MichaB.
Post12-09-2004, 7:48    Subject: Power Relay 1Z: Reliable & Efficient Quote
'Thank you!'
I didn't know that this was about the 109, which has already been discussed so much.
'Inspected the expanded part... it looks quite damaged. I'll just get a new one and then see how it goes!'
Hi Micha,
Translated on 06-09-2026, 8:30.
