GRA, the 327th... completely desperate!
Peacemaker0409
Post22-04-2002, 22:08    Subject: GRA, the 327th... completely desperate! Quote
After having searched through the archives and not knowing where else to look, I'm going to ask the question again:
Is it possible to unlock the GRA (Gas Recirculation System) on a Passat TDI (AFN)?
If so, how do I proceed? First, should you release the mechanism, then install the lever, or vice versa? What else should be considered?
Does anyone have any advice?
I would be very grateful for help from experienced mechanics!
Peacemaker0409
Translated on 05-07-2026, 16:47.
Peacemaker0409
Post22-04-2002, 23:04    Subject: more precisely... Quote
More specifically, it's a Bj10/97 model, and I've heard that this designation might have something to do with the year of manufacture. To be completely honest, I've heard some of the most contradictory things.
Translated on 05-07-2026, 16:48.
Rudi
Post23-04-2002, 6:27    Subject: 10/97 is a go! Quote
You will need a VAG tester or a PC/laptop with an adapter and VAG-COM to unlock it.
It's not a problem if the GRA is enabled and there's no switch or button connected to it!
If you need the installation instructions, please send me an email.
Translated on 05-07-2026, 16:49.
Diesel-Dirk
Post23-04-2002, 8:12    Subject: Take a look here Quote
http://www.jagiella.net/dirk/dirk.htm
Peacemaker0409
Post23-04-2002, 8:40    Subject: I already understood that Quote
I already understand. My VW dealer charges 10€ to unlock it. So, that's not the problem, my question is whether it's even possible?
Olly.
Translated on 05-07-2026, 16:50.
Rudi
Post23-04-2002, 8:58    Subject: Price Quote
I already mentioned that above.
I think it's quite outrageous to charge 10,000 euros to unlock it.
If you might need an interface to access vehicle electronics, I would invest the money in a VAG-COM adapter (assuming you're comfortable with soldering).
Peacemaker0409
Post23-04-2002, 12:02    Subject: GRA, the 327th... completely desperate! Quote
First of all, thank you, but I think I'll pass on that; soldering is definitely not my forte.
Translated on 05-07-2026, 16:51.
Jürgen
Post23-04-2002, 15:29    Subject: GRA code Quote
Hello!
Okay, so I installed the GRA components one after another in my Golf 4.
Engine AHF, automatic transmission, and engine AFN, automatic transmission, for the Passat.
Upgraded for my wife!
'Unlocked before installation in the vehicle.'
'The installation of both was straightforward and trouble-free.'
Unlock code for all VAG vehicles where the...
Function exists in EDC = 11463.
Be careful when purchasing a kit for the Volkswagen Golf 4 from VAG.
- mine came with an instruction manual for the Golf 3.
However, there is an instruction manual available at www.gute-fahrt.de.
The instructions for the Passat are missing a step.
Power supply 1.
In addition, there are 2 different kits available for the Passat.
depending on the part number!
Jürgen
Translated on 05-07-2026, 16:52.
Peacemaker0409
Post23-04-2002, 15:47    Subject: how FGNR????? Quote
Vehicle identification number?
What exactly was that supposed to mean?
Translated on 05-07-2026, 16:54.
Jürgen
Post24-04-2002, 10:52    Subject: GRA-Kits Passat Quote
Hello.
Take a look at www.gute-fahrt.de under the 'rat&tat' section – there's an article about it!
The following kits are available - up to model year 1997, part number 3BV120000.
Part number 3B0998527, valid from model year 98, VAT number 3BW001, same part number with...
Sure, here is the translation of the text from German to English, with an extra 'a' at the end:
'a'
Best regards, Jürgen.
No new posts Touran & A3 (8P): RME Incompatible - No Go! Diesel Engine Technology
