1.9 TDI vs. 2.5 TDI: Differences in smoke emissions?
saxi
Post01-07-2002, 21:04    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
Hello everyone!
Is it actually true that a 2.5 TDI engine produces more smoke from the start compared to a 1.9 TDI? I drove behind an older Audi 2.5 103 kW Quattro today, and it was also producing a significant amount of gray-black smoke. It was a bit less than mine icon_rolleyes.gif. Could the gray smoke be related to the exhaust gas recirculation system? How can I deactivate the EGR system on an AAT engine? Can someone describe how it works and whether it helps with gray smoke?
'Thank you.'
Avatar-Jan6K
Post01-07-2002, 21:08    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
I need to confirm that thing about the 2.5s... most of the ones I encounter tend to misfire when accelerating, and it's noticeable, sometimes even with a smell.
Jan.
1Z5 CFHF / AHB H4D
Stefan .
Post01-07-2002, 22:03    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
Hi.
I also have a 2.5 (AFB) Quattro, and it only smokes when there's an issue with the electronics, meaning the engine control unit isn't reset regularly during inspections.
Just like with the older 1Z or AFN engines, the technology is quite similar.
...or with a chip.
icon_wink.gif Stefan.
GarfieldMZ
Post02-07-2002, 22:44    Subject: I've never heard of that before... Quote
Hello Stefan!
'I also drive an AFB... well, it actually runs pretty well under full load. But I've never heard that you reset the engine control unit during inspections. Sure, you reset the maintenance interval display, but the entire control unit? What's supposed to happen or change with that?' And what exactly does it mean?
DENNIS
Hi.
...or with a chip.
Stefan .
Post05-07-2002, 0:00    Subject: To the best of my knowledge Quote
Hi!
As far as I know, the control unit stores dynamic data in memory that it 'learns' itself after a control unit reset.
If these data are not 're-learned' over an extended period, some parameters will no longer be accurate. Whether it's due to wear and tear or other factors, such as modifications.
My experience: Seat Toledo 1Z, after approximately 60,000 km, it started to smoke more and more, and all inspections had been carried out up to that point.
At 75,000 km, I took it to the workshop, and they reset the control unit, and the smoking stopped.
My old Bora (AJM) started smoking like a steam locomotive after about 30,000 km -> I asked a workshop about it, but they didn't know anything. Other workshop: 'Sure, we can do that.' The smoke was gone.
The same applies to the A4 AFB. When it smokes, the workshop knows what's up.
If I've been talking complete nonsense, please feel free to (virtually) slap me or tell me the truth. icon_wink.gif
Post05-07-2002, 11:12    Subject: @Stefan Quote
new_tomato.gif Plong....
If such "learning values" were to be stored, they would have to be placed in the EEPROM of the control unit, since relay 109 already draws power from the control unit when the ignition is off.
However, I haven't found anything like that in my VAG documentation for the AHF engine or other TDIs. The only thing that comes to mind for reducing smoke emissions via the engine control unit is to adjust the air mass values. This would reduce the injection amount when there is an insufficient amount of combustion air, which would decrease soot emissions, but it would also reduce the engine's power.
Perhaps Michael knows more about this and can correct me.
Michael II
Post05-07-2002, 11:40    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
Hello Rainer,
I can only confirm your opinion.
The learning values for idle stabilization and smooth running control are always determined and adjusted dynamically.
If the car is smoking excessively and you want to try adjusting it using the adaptation channels:
1. Option: Reduce LMM value.
2. Option: Reduce injection volume.
Tschüss
Michael II
Stefan .
Post05-07-2002, 23:27    Subject: Ouch! Quote
AND: What does the EEPROM do in my control unit if it doesn't have any dynamic data? Data storage?
Post06-07-2002, 13:06    Subject: Re: Ouch! Quote
Stefan . wrote:
I have no idea, but did they sacrifice a black cat inside a pentagram next to the car?
How about the fault memory and data from the adaptation channels?
Stefan .
Post06-07-2002, 17:23    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
Ha!
Okay, if cats have SUCH an effect, I'm going straight to the animal shelter on Monday and getting some. icon_twisted.gif
I looked for it, but unfortunately, I can't find the invoice from back then for my Seat Toledo anymore.
At that time, I called 3 or more vendors and asked if they could do it, and they all said yes, but the prices were different.
Hmph...
Stefan .
Post12-07-2002, 17:55    Subject: Now it's my turn! Quote
Today, I visited both an Audi service center and an independent workshop equipped with a Bosch diagnostic computer. (It's similar to VAG's 1552, but made by Bosch and compatible with almost all vehicles and brands.)
BOTH told me AND showed me that the engine control unit can be reset to its default settings!
There are even dedicated menu options for it, and certain conditions (engine temperature, air conditioning off, etc.) must be met in order to do it. icon_idea.gif
So, please, whoever claims that my statement above was incorrect should contact me at Watsch'n. icon_cool.gif
Post12-07-2002, 19:55    Subject: 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Quote
Hello Stefan,
Sure, you can set the engine control unit into the basic settings-mode.
In this process, only specific actuators (e.g., injection volume adjusters) are supplied with defined signals to adjust the mechanics icon_exclaim.gif using a wrench to the desired values.
Timing belt replacement, followed by a basic adjustment to set the injection start of the injection pump. This ensures that in the subsequent operation (non-default mode), the engine control unit can regulate the injection start within the intended range, and that the correct injection timing is maintained during engine start, when the EDC system is not yet active.
Therefore, during the initial setup, it is not the control unit that is adjusted, but rather the mechanical components.
If anyone knows any other secrets of the default settings mode that I am unaware of, please contact me icon_wink.gif.
No new posts Smoke after startup: Causes and solutions. Diesel Engine Technology
No new posts vtg-17, vtg-15.. wo ist der unterschied Diesel Engine Technology
No new posts unterschied zwischen aat und ael? Diesel Engine Technology
No new posts Control Unit Differences On-Board Diagnostics (OBD)
