Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Audihuhu
Post22-09-2004, 17:29    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
I am completely new here and have already been reading for several hours.
However, I haven't been able to find the measurement blocks that I'm looking for.
Search for measurement blocks for 2.5 TDI 140hp Engine: AEL
and to 1.9 tdi 110PS Engine: AHF
Error 550 in the AEL fault memory, I've already done some research on the possible causes.
I would also like to have all the measurement blocks.
Maybe someone can help me, that would be great.
Thank you so far
I only contacted the AEL about 2 months ago, so I still have some questions. icon_redface.gif
Greetings
Peter
joergs
Post22-09-2004, 17:40    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
Sales data to AHF:
http://www.dieselschrauber.de/Solldaten_4_Zylinder_VE.html
Target date for AEL:
and to 550:
/viewtopic.php?t=1787&highlight=550+ael
Audihuhu
Post22-09-2004, 18:22    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
These are both the same target value lists.
And both are for 4 cylinders, while the AEL is a 5-cylinder.
Theresias
Post22-09-2004, 18:30    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
These are both the same specification lists.
Then scroll to the right on the page...
Michael II
Post22-09-2004, 18:35    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
http://www.dieselschrauber.de/Solldaten_Main.html
@Audihuhu
It's clear that your problem is really bothering you.
But please use the search function more often next time.
Tschüss
Michael II
Audihuhu
Post22-09-2004, 18:36    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
'Although the ALEs are present, they will actually be from the AEL.'
Michael II
Post22-09-2004, 18:38    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
ALE is not the same as AEL.
Therefore, my link above. This leads to the selection page.
There you will also find the 5-cylinder. AEL.
Tschüss
Michael II
Audihuhu
Okay, hier ist die Übersetzung:
Thank you, I understand now.
Sorry
I've been searching for a long time but haven't found anything.
joergs
Post22-09-2004, 19:11    Subject: Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL and 1.9tdi AHF Quote
Sales data for AHF:
and to 550:
sorry, it must of course
http://www.dieselschrauber.de/Solldaten_5_Zylinder_VE.html
name
@audihuhu
I'm sure you didn't look for something {SO SPECIFIC}.
No new posts Suche dringend Schaltplan Golf 4 Upload
No new posts Suche dringend Login für Getriebesteuergerät A6 Allroad... On-Board Diagnostics (OBD)
No new posts Measurement data blocks 001-137 On-Board Diagnostics (OBD)
No new posts Measurement blocks, A4 size, 2001-? MKB: AWX, AVF On-Board Diagnostics (OBD)
