tannen Guest
28-08-2004, 18:10 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
Hello.
Problem: The vehicle has poor traction.
Yesterday, I performed a diagnostic test using VCDS and logged the turbo pressure.
The pressure was almost always close to the displayed setpoint. Is it normal for the pressure to fluctuate constantly? I always thought it would be more stable.
eventually settle at a certain value.
Okay, yes. The air mass flow is also too low. I think that's related to the turbo pressure.
Could it also be that the turbo pressure is acting up due to a faulty mass airflow sensor?
How can I safely test the boost pressure control system?
Translated on 18-09-2026, 23:35.
Marco Guest
28-08-2004, 18:37 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
Just post the log. Then we won't have to guess.
Translated on 18-09-2026, 23:36.
29-08-2004, 13:34 Subject: TDI Boost Pressure: Golf 4 1.9 Performance |
tannen wrote: | Is it normal for the pressure to constantly fluctuate? I always thought it would eventually settle at a certain value.
Oh yeah, the mass airflow is also too low. |
That fits perfectly.
Translated on 18-09-2026, 23:37.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
29-08-2004, 15:03 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
I've moved it to this new thread. Please don't always create a new thread!
Translated on 18-09-2026, 23:38.
Profile PM Garage |
AndreasG Guest
30-08-2004, 13:41 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
Please review the troubleshooting articles, especially.
A quick test using the diode described there will immediately and easily show you whether the mass airflow sensor is faulty or if the problem lies elsewhere -> technical article.
Please mention your mileage and the total distance driven next time.
tannen Guest
19-09-2004, 19:31 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
Hello.
First of all, SORRY about the previously opened thread that was unnecessarily created. It was an accident  .
The mass airflow sensor (MAF) was defective in the vehicle.
I have one more question regarding VCDS (Vag-Com).
When I log group 11 (boost pressure), I see a line showing the current boost pressure and another showing the target pressure. Is the target pressure curve recalculated, so that it would also be incorrect in case of a defect? Or is it stored in the control unit? (In other words, if the actual pressure follows the target pressure curve, it's a good indication that the boost pressure control is working correctly?)
Translated on 18-09-2026, 23:40.
20-09-2004, 16:40 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
tannen wrote: | | When I log group 11 (boost pressure), I see the line showing the current boost pressure and another showing the target pressure. Is the target pressure curve recalculated, and therefore incorrect in case of a defect, or is it stored in the control unit? (In other words, if the actual pressure follows the target curve, it's a good indication that the boost pressure control is working)?????? |
Normally (meaning: under normal external conditions), the target pressure is, as far as I know, primarily determined based on the throttle position and the current RPM, using a lookup table – regardless of any defects in the engine.
As long as "Ist" is equivalent to "Soll," then the arrangement is okay.
Translated on 18-09-2026, 23:41.
Profile PM Garage |
tannen Guest
20-09-2004, 20:12 Subject: Boost Pressure Curve Golf 4 1.9 TDI |
Thank you for the answers.
Spruce trees.
Translated on 18-09-2026, 23:42.
