Question about oil lines for Turbo 1Z - I'm working on it
Post28-09-2004, 21:36    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
Hi.
- I've now loosened all 8 Kruemmer screws.
- The exhaust pipe has already been removed and is lying next to it.
- The oil pressure line is also disconnected (this stupid screw in the turbo wanted to come out with it icon_evil.gif).
Now the question:
Should I disconnect the return line from the turbo, or this huge nut on the engine block?
If it's supposed to be at the top of the block, will the oil leak out under normal oil levels and with the car on a level surface?
I don't feel like flooding the garage.
The return pipe is secured to the turbo with 2 screws, one of which is hidden by the bend in the pipe (super design icon_evil.gif).
If you reply tonight, the price will still be the same icon_wink.gif.
"Thank you."
Jan6K
Avatar-Jan6K
Post28-09-2004, 21:57    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
Hi Martin,
I'm sorry that I can't really answer your question, but:
Once you have everything put back together, you'll need a new keyboard; it must be completely clogged with oil and EGR sludge icon_wink.gif).
Regarding your issue:
"Simply measure how far the oil level is on the dipstick, relative to, for example, the cylinder head, and then apply that measurement to the corresponding oil line on the other side of the engine. Since you haven't driven the car in the last three days, there should only be a minimal amount of oil in the turbo, and everything else should have drained down into the oil pan. Therefore, I would consider it safe, assuming it's clearly above the oil level in the pan (which I suspect it is)."
Jan.
1Z5 CFHF / AHB H4D
Post28-09-2004, 22:03    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
Hi Jan,
The measuring process is now too complicated for me icon_wink.gif. I could also simply drain the oil - but then I would be tempted to also install the oil pan gasket that I already have ready... Actually, he should be able to run again sometime icon_wink.gif.
The easiest thing would be if someone KNEW how high the oil level normally is.
Here are the latest pictures of the Golf:
http://www.luxus-wg.de/~martin/auto_bilder/Kruemmer/
Post28-09-2004, 22:36    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
It's been taken care of.
The oil icon_twisted.gif is not that high - I just opened the 24mm screw icon_smile.gif.
Kruemmer incl Turbo is standing next to me right now, and we are watching .
Martin L.
Post30-09-2004, 21:12    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
If you're installing a new turbocharger now:
- Before connecting the hoses, fill the lines on the loader with oil as much as possible.
- For the initial run, let the engine idle at best. Do not accelerate! Ideally, run the engine for the first few revolutions without ignition or fuel injection, using only the starter motor. The oil pump is already pumping, but you don't have any exhaust pressure...
He should be doing well.
MichaB.
Post01-10-2004, 7:29    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
hi,
'so, 'filling oil lines' seems to be somewhat misrepresented icon_lol.gif'
Add a few drops of oil into the oil channel from above, let it sit for a moment, rotate the shaft a little, and then add a bit more, but don't overfill it. That should be enough until the oil pressure builds up.
Hi Micha,
Post01-10-2004, 9:08    Subject: Question about oil lines for Turbo 1Z - I'm working on it Quote
No, there wasn't a new turbo.
I've put everything back together, and it's still working icon_smile.gif.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dringende Frage zum Turbo... Diesel Engine Technology
No new posts VGT-Turbo to AHU Diesel Engine Technology
No new posts 1.9 TDI PD ASZ Oil on Turbo Diesel Engine Technology
No new posts Turbo AAZ <--> Turbo 1Z Diesel Engine Technology
