USB Diagnostic Adapter: Access Engine Control Unit
muellet2
Post11-10-2004, 17:59    Subject: USB Diagnostic Adapter: Access Engine Control Unit Quote
Unfortunately, due to a recent purchase, my laptop no longer has an RS232 interface. Therefore, I acquired a USB adapter that currently emulates the COM4 port.
Unfortunately, I can only currently log in to the engine control unit; I can't find the others anymore.
Does anyone have a solution for me?
Toby.
Translated on 30-09-2026, 22:11.
joergs
Post11-10-2004, 18:15    Subject: USB Diagnostic Adapter: Access Engine Control Unit Quote
This has been discussed in several threads here, with the note that it might work, but it doesn't have to. Ross-Tech discourages the use of such adapters.
As I said: it might work, but it doesn't have to. It seems you belong to the latter group...
Translated on 30-09-2026, 22:12.
Karma: +805 / -0   Thank you, like it!
Post11-10-2004, 18:36    Subject: USB Diagnostic Adapter: Access Engine Control Unit Quote
Yes, buy a reasonable USB diagnostic adapter icon_mrgreen.gif.
The reason is as follows: When a diagnostic interface without its own intelligence (microprocessor) is used with VAG-COM, the Windows PC must control the entire timing of the diagnostic protocol.
Windows is not a real-time operating system, and there are no corresponding kernel drivers. Therefore, no programs that may temporarily halt the system (such as antivirus software) should be running while using VAG-COM.
When a COM port is emulated via USB, an additional, undefined timing behavior is introduced.
Emulated COM port, driver -> USB driver -> USB controller on the motherboard -> USB to COM interface converter -> serial level converter -> K-Line -> microcontroller in the gateway/control unit. This is not going to work properly.
The KKL+CAN (USB) diagnostic system looks like this:
USB Driver -> USB Controller on the Mainboard -> Microcontroller in the Diagnostic Adapter -> K-Line/CAN -> Microcontroller in the Gateway/ECU. Due to the built-in microprocessor, timing problems are almost eliminated. icon_smile.gif
Translated on 30-09-2026, 22:13.
Gremlin
Post11-10-2004, 18:52    Subject: USB Diagnostic Adapter: Access Engine Control Unit Quote
or:
Use a reliable USB-to-serial adapter.
'In their professional roles, our field technicians need to operate a wide range of devices with COM interfaces. However, the new laptops only have USB ports.'
There are huge differences between various adapters.
'When he's back, I'll ask him what exactly he has.'
CU Gremlin.
Translated on 30-09-2026, 22:15.
joergs
Post11-10-2004, 19:26    Subject: USB Diagnostic Adapter: Access Engine Control Unit Quote
...or search within this forum...
There is experience in this regard.
Translated on 30-09-2026, 22:16.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM via USB-RS232 Adapter: How-to On-Board Diagnostics (OBD)
No new posts VAGCOM Adapter: Change/Info on Optocouplers Diesel Engine Technology
No new posts Engine Control Unit Login On-Board Diagnostics (OBD)
No new posts Engine Control Module Login 8E0 907 401P On-Board Diagnostics (OBD)
