Adjusting the Lucas fuel injection pump
BigB
Post04-10-2004, 20:20    Subject: Adjusting the Lucas fuel injection pump Quote
Hey everyone,
While my car might not have all the latest technology, you can still achieve a lot with just wrenches, a bit of intuition, and the help of a VAG-COM diagnostic tool.
'Today, I adjusted the idle speed of my Skoda Felicia LX 1.9D, reducing it by about 200 RPM. Now it idles smoothly at 900 RPM, whereas before it was quite erratic.'
Here's the translation:
'To help me, you'll probably need some information about the pump. As I said, it's called Lucas and it's installed in my Skoda, but it's the standard VAG 1.9 SDI model.'
VAG-Com says the following about it:
Address 41 -------------------------------------------------------
Controller: 028 906 125
Component: Diesel engine (naturally aspirated) V03
0 Faults Found:
That's already great, with zero errors.
I hope you can help me. I want to adjust this thing so that I have less idle speed and more power at the top end. I've already thought about dynamic additional boost reduction, but I want to see what I can achieve first using the available settings.
Best regards, BigB.
Translated on 08-07-2026, 23:43.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Caddy 1: Adjust 1.6L TD Fuel Injection Pump Diesel Engine Technology
No new posts 1.6 TDI Not Running? Adjust Fuel Injector Pump Diesel Engine Technology
No new posts Lucas fuel pump for VW and Skoda??? Diesel Engine Technology
No new posts Ford Transit / Lucas DSA947 goes into limp mode under load On-Board Diagnostics (OBD)
