Golf 1Z Power Loss: Troubleshooting & Repair
problemauto
Post12-04-2004, 19:12    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
'When I exceed an engine speed of approximately 2200 RPM, the engine loses a significant amount of power. The mass airflow sensor (MAF) has been replaced, but the problem persists. What's strange is that this issue only occurs sporadically. For four weeks, it ran perfectly fine, but then, again, it starts running poorly for weeks.' What do you think the problem could be?
Translated on 26-08-2026, 3:42.
Thomas
Post13-04-2004, 14:35    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
Have you already read the error codes?
If so, what are the error messages?
Wie groß ist die Laufleistung Deines Autos? Tuned/untuned?
Does the performance drop off, or does it feel like 70 horsepower from the beginning?
Is a boost pressure indicator available?
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 26-08-2026, 3:43.
reuselkopp
Post18-10-2004, 8:46    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
I'm experiencing the exact same problems with my 1Z model, manufactured in 1995. Are there any new findings on this issue?
Post18-10-2004, 13:51    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
Keywords:
- Mass airflow sensor (don't just replace it, also check what readings it's providing!).
- Boost pressure
And then drive for as long as it takes for the error to occur, while analyzing both values.
That has already been mentioned several times in this forum icon_wink.gif.
...and that's all that can be said based on this error description.
Translated on 26-08-2026, 3:44.
Benno
Post18-10-2004, 19:54    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
I had a similar problem. Check the wiring harness to see if you might have a broken wire. In my car (1Z), I had one right near the MAF sensor connector. The error would appear sometimes more, sometimes less, depending on the resistance, and it didn't always leave an entry in the error memory.
Best regards, Benno.
Translated on 26-08-2026, 3:45.
Post18-10-2004, 20:00    Subject: Golf 1Z Power Loss: Troubleshooting & Repair Quote
@ Benno
You can easily identify such things by looking at the LMM values.
Install the diode and then take it for a test drive - at that point, the mass airflow sensor (MAF) values shouldn't change.
I already noticed a problem with the mass airflow sensor (MAF sensor) -> the MAF sensor value suddenly dropped to 0, and the 110 hp TDI engine suddenly lost power, only to immediately regain full power - it was a wild ride.
Translated on 26-08-2026, 3:46.
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 1.8T Power Loss: Causes & Fixes Upload
No new posts Golf TDI: Power Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Golf 4: Troubleshooting Performance Loss On-Board Diagnostics (OBD)
No new posts Performance loss Golf TDI PD, Year 2001, 115 hp Diesel Engine Technology
