Blind Plugs LLK: Reliable & Durable Seals
Jan6K
Avatar-Jan6K
Post13-07-2002, 20:44    Subject: Blind Plugs LLK: Reliable & Durable Seals Quote
Hi Rainer,
Today, I finally got to visit my parents, and I also brought my digital camera to document it for you.
Unfortunately, it turned out that my memory had deceived me; that stupid thing doesn't have a blind plug at all! What I had mistaken for a blind plug in those old and bad pictures was actually one of the mounting points.
I also took a new series of photos with a modern camera (at that time I only had a blurry webcam), which you are welcome to use if you ever want to document the effects of damaged LED streetlights on the site - the damage is very clearly visible.
But unfortunately, it also means that there is no blind plug available.
I'm sorry that I can't help you with your question.
Here's another recent picture (resized, the original is MUCH larger) of the part:
http://www.informatik.hu-berlin.de/~richling/tmp/llk.jpg
Is the dashboard layout in the A3 the same, or does it look fundamentally different from the start?
Jan.
1Z5 CFHF / AHB H4D
Translated on 26-10-2026, 6:42.
Karma: +807 / -0   Thank you, like it!
Post13-07-2002, 22:34    Subject: Blind Plugs LLK: Reliable & Durable Seals Quote
Hello Jan!
"Thank you, but it's not that bad; the blind plug is sealed, and I hope it stays that way."
I can't tell you for sure if my cooling liquid is the same without taking it out: I haven't actually seen it myself.
Translated on 26-10-2026, 6:44.
