7-Digit Login Code: Find & Generate Now
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Bee
Post07-11-2004, 22:25    Subject: 7-Digit Login Code: Find & Generate Now Quote
Hi everyone,
I've Googled, searched the forum, and I'm still stuck with my problem.
Car: 1J, AXR, Pacific special edition, manufactured in 2004, model year 2005.
I would like to make some adjustments to the comfort control unit and parking distance control using VAG-Com (disable the flashing lights when unlocking and reduce the volume of the parking sensors).
The location of the control units is known, and the channels that need to be adjusted are also identified.
Problem: The login code '12233' only works for the engine control unit. I am therefore looking for a 7-digit login code with WSC, importer number, date, and time. The customer service representative is being unhelpful.
Does anyone happen to have a corresponding code, or does anyone have a program that generates these codes?
Sure, here's the translation:
'Thank you in advance.'
'Micha'
Translated on 25-10-2026, 21:56.
Theresias
Post08-11-2004, 2:35    Subject: 7-Digit Login Code: Find & Generate Now Quote
You don't need to log in to make the adjustments you requested.
Translated on 25-10-2026, 21:57.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for login code for comfort control unit On-Board Diagnostics (OBD)
No new posts Login Code for Comfort Control Unit Diesel Engine Technology
No new posts ECU Login Code: How to Find & Use On-Board Diagnostics (OBD)
No new posts AEL Motor Login Code: Start Quantity Example On-Board Diagnostics (OBD)
