CD control radio Gamma 4
mabumeti
Post31-10-2004, 16:33    Subject: CD control radio Gamma 4 Quote
Hi everyone, (VW Passat TDI, 81 kW, year of manufacture 1996).
I want to use my MD player with the CD player's controls. I bought an adapter cable for this, but I'm not getting any signal. It says 'no CD.'
Is there a solution to this?
Do I need a trigger signal, and if so, how can I generate it and with what voltage?
or do I have to build a connector myself with the correct wiring?
I know that the focus here is mainly on engines and such, but I could use a little help. Thank you, and goodbye.
Post31-10-2004, 17:31    Subject: CD control radio Gamma 4 Quote
You need a CD changer simulator.
http://home.tiscali.de/matthiasklumpp/index.html
mabumeti
Post31-10-2004, 21:28    Subject: hmmmhmmmm Quote
icon_biggrin.gif thank you for the quick reply.
If that also applies to a MiniDisc player, then that might be the solution.
I wonder if it's possible to build something like that yourself?
Ultimately, my Gamma 4 radio is just missing a CD signal input. Or am I wrong?
Which version is right for me?
'Thank you very much anyway, and I will contact Klumpi to find out exactly what I need to do. See you, and thanks, mabumeti.'
P.S. I am always open to further solutions!
No new posts Reprogramming the AGR control? Diesel Engine Technology
