A3 TDI: Power Loss on Hills (ALH Engine)
Janosch74
Post04-11-2004, 15:27    Subject: A3 TDI: Power Loss on Hills (ALH Engine) Quote
'When I'm driving uphill in 5th gear under full load for an extended period, the power occasionally cuts out suddenly. This happens abruptly, and it's difficult to maintain speed.'
Sure, my first thought is: Mass Air Flow sensor (MAF sensor).
However, it has already been replaced, although the new one might also be broken (that has happened before).
But now, the phenomenon: I briefly turn off the ignition, restart, and the power is back. Could this be related to the mass airflow sensor, or does anyone have another idea? If the error occurs again, I'll need to have the error codes read.
Thank you for your suggestions.
Janosch.
Translated on 20-10-2026, 16:18.
Marco
Post04-11-2004, 15:30    Subject: A3 TDI: Power Loss on Hills (ALH Engine) Quote
Hello Janosch74,
Search for 'Notlauf' within this forum.
Translated on 20-10-2026, 16:19.
Post04-11-2004, 16:02    Subject: A3 TDI: Power Loss on Hills (ALH Engine) Quote
Hi.
It would have been helpful if you had read the error memory _first_.
Because there will definitely be a "00575" included in that.
And so that you understand how to continue searching (both here in the forum and on the car).
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts Diesel Temperature & Intake Air Temp Under Load Diesel Engine Technology
No new posts 1.4 TDI Fuel Consumption Under Full Load Diesel Engine Technology
No new posts Tuning Box: Reduce Soot & Improve Performance Diesel Engine Technology
No new posts Allroad AKE V6 2.5TDI: Low Power Below 2500 RPM Diesel Engine Technology
