Technical specifications ARL engine, 150 hp
Go to page: 1, 2  Next
Fliegerstefan
Post08-10-2004, 8:17    Subject: Technical specifications ARL engine, 150 hp Quote
Hello.
I am looking for the technical specifications of the ARL engine, such as... B.
Boost pressure (max/min), etc.
and practical experience regarding how much further it can be improved.
Thank you everyone.
Pilot Stefan.
Post08-10-2004, 9:23    Subject: Technical specifications ARL engine, 150 hp Quote
Okay, then.
Here in the forum, you can find tables that list all known engine specifications, including those for the ARL and all other models.
There is also an overview of the GKB.
So, please search first; maybe that will answer your questions and familiarize you with the forum!
Post08-10-2004, 9:28    Subject: Technical specifications ARL engine, 150 hp Quote
@MatthiasTDI96:
If I've looked correctly, the ARL is not in the table of target values...
Fliegerstefan
Post08-10-2004, 11:44    Subject: Technical specifications ARL engine, 150 hp Quote
Hello Mathias,
Unfortunately, I've already done all of that. The ARL is not included in the tables.
You can be sure that I already checked that beforehand.
If anything 'should be there,' I'm sure you'll help me with a link.
Thank you.
Pilot Stefan.
Post08-10-2004, 19:41    Subject: Technical specifications ARL engine, 150 hp Quote
Oops, that's what you get... it doesn't actually say that.
I am ashamed.
Fliegerstefan
Post11-10-2004, 9:08    Subject: Technical specifications ARL engine, 150 hp Quote
Hopefully, the embarrassment is just the beginning.
Post11-10-2004, 9:41    Subject: Technical specifications ARL engine, 150 hp Quote
If you have VAG-COM, you can see the target values for things like boost pressure, injection timing, etc.
Fliegerstefan
Post11-10-2004, 11:08    Subject: Technical specifications ARL engine, 150 hp Quote
Hello Rainer,
Thank you for the information.
VAG-COM shareware available.
I understand that the target values are mostly displayed by VAG-COM.
I also want to know what else can be 'extracted' or 'gained' from that.
With the installation of a P-BOX, there is now a development that I want to prevent by providing 'more headroom.'
That's why my question is about the boost pressure.
Could the boost pressure be slightly increased by potentially modifying the pressure sensor (e.g., with a resistor) without causing any immediate issues, and would the rest of the drivetrain (engine, all-wheel drive) be able to handle a further increase in power?
When logging data with VAG-Com, it's noticeable that the turbocharger boost pressure is reduced starting around 3800 RPM.
Drehz: Speed
Soll: Target/Setpoint
ist: Actual/Current
Tastverh.: Button function/Control via buttons
3738 2499 2457.0 79.3
3759 2499 2468.7 79.3
3801 2489 2480.4 80.1
3822 2489 2480.4 80.1
3864 2479 2480.4 80.1
3885 2468 2480.4 80.5
3927 2468 2480.4 81.3
3969 2458 2480.4 81.3
3990 2448 2480.4 82.1
4011 2448 2480.4 82.5
4053 2438 2480.4 82.5
4074 2428 2468.7 83.7
4116 2387 2468.7 87.3
This likely happens through the duty cycle.
Therefore, I assume that the charger is not yet experiencing any issues with overheating.
Thank you for your support.
Stefan.
Post11-10-2004, 12:19    Subject: Technical specifications ARL engine, 150 hp Quote
Fliegerstefan wrote:
When logging data with VAG-Com, it is observed that the boost pressure is reduced starting at approximately 3800 RPM.
Bitte gib den Text an, den du übersetzt haben möchtest.
Therefore, I assume that there is currently no sign of the charger overheating.
That's right: ultimately, it's the decreasing target value that matters.
Fliegerstefan
Post11-10-2004, 12:29    Subject: Technical specifications ARL engine, 150 hp Quote
Yes, that's why I'm asking.
Is it possible to increase the boost pressure, for example, by 100 mbar, so that this additional 100 mbar is still present even at high engine speeds?
Or are 1.6 bar of pressure below 3800 RPM perhaps too much?
Stefan.
Post11-10-2004, 19:01    Subject: Technical specifications ARL engine, 150 hp Quote
Is it possible to increase the boost pressure, for example, by 100 mbar, so that even at high engine speeds, these additional 100 mbar are still present?
It's probably possible, and likely already achievable with a 10c tuning.
Or are the 1.6 bar below 3800 RPM perhaps too much?
I don't believe the ARL charger has such limited reserves.
It's just a rough estimate...
Fliegerstefan
Post11-10-2004, 19:24    Subject: Technical specifications ARL engine, 150 hp Quote
Hello Ulf,
It's not just about the charger.
What's the point if the loader itself is durable, but the engine, the transmission, or the (Haldex clutch) fail?
Supposedly, the engine with the turbocharger already produces 175 horsepower and 370 Nm of torque.
Perhaps there's some experience to be shared regarding this. B. that the all-wheel drive can handle it.
Definitely, I don't have any slippage anywhere now, icon_lol.gif neither in the clutch nor in the wheels.
Post11-10-2004, 19:42    Subject: Technical specifications ARL engine, 150 hp Quote
What's the point if the charger lasts, but the engine, the transmission, or the (Haldex (clutch)) fails.
icon_idea.gif I wouldn't be afraid of that:
Increasing boost pressure alone generally does not provide any additional power when tuning a turbocharged engine.
Fliegerstefan
Post11-10-2004, 19:52    Subject: Technical specifications ARL engine, 150 hp Quote
Thank you, Ulf.
Since you're probably the ultimate expert on C++, could you perhaps give me a little guidance regarding... Increase boost pressure.
I know where the sensor is located (likely with 4 connections, probably for temperature and pressure).
Stefan.
Post11-10-2004, 20:01    Subject: Technical specifications ARL engine, 150 hp Quote
Since you're probably the absolute 10 C specialist, maybe you could give me a little guidance regarding... Increase boost pressure.
I know where the sensor is located (it probably has 4 connections, likely for temperature and pressure)
Disclaimer:
Measure the veins.
1 is likely the mass, 2 is probably the temperature signal, 3 is the pressure signal, and 4 is the 5-volt power supply.
(Please post if you know a better translation!)
2. If that's correct, connect a diode like a 1N4148 in series with the cable, with the cathode (banded end) pointing away from the sensor.
3. Connect the (temporary) LDA and perform a cautious test drive, observing the boost pressure. If everything is normal, adjust to the maximum. Feeling for pressure.
4. In case of emergency or other problems, please post again with detailed symptoms and measurements.
Fliegerstefan
Post11-10-2004, 20:05    Subject: Technical specifications ARL engine, 150 hp Quote
Hello Ulf,
is it a diode or a resistor?
How does that increase the boost pressure? Can it be influenced? Other diodes, etc.?
Stefan.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
No new posts Coolant Temperature Sensor Passat 35i - Technical Specifi... Diesel Engine Technology
No new posts Daten zum AYQ-Motor gesucht Diesel Engine Technology
No new posts Data from Arl engine showing poor start and acceleration;... Diesel Engine Technology
