Cylinder Volume Difference: Analysis & Optimization
Marco
Post04-11-2004, 17:35    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
Hello fellow enthusiasts,
I've been wondering for a while how the engine control unit (ECU) detects weaker and stronger cylinders and then adjusts the fuel injection accordingly. What measurement parameters are relevant for this? I'm not entirely clear on how it works.
Translated on 11-10-2026, 20:38.
Julian
Post04-11-2004, 17:41    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
In short:
The crankshaft speed is measured. The engine control unit (ECU) knows which cylinders are currently firing.
For example, if a cylinder's crankshaft speed increases slightly after the fuel is ignited, the corresponding cylinder is adjusted to reduce its output.
Marco
Post04-11-2004, 17:42    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
Ah, I understand. Thank you!
Translated on 11-10-2026, 20:39.
Gremlin
Post05-11-2004, 8:28    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
'The older' TDI engines had 4 markings per revolution on the crankshaft position sensor (one for each ignition top dead center). (PD engines have a 60-2 sensor).
The EDC is now trying to maintain a constant time interval between the injection pulses, meaning it adjusts the cylinder power so that all cylinders have the same output. These are the values that you can read out in the idle speed control.
'With the VP-37 engines, this is only relevant at idle. At higher speeds, the control system is too slow to compensate for individual cylinder imbalances (although it is still possible to measure and display the deviation).'
For VP-30 and VP-44 models, this also applies in the mid-speed range.
Of course, with PD.
This is mainly for comfort reasons, as 'idle jerk' is a term icon_wink.gif.
By the way, this whole story takes up a significant amount of space in the EDC software!
CU Gremlin.
Translated on 11-10-2026, 20:40.
wolfi_b
Post05-11-2004, 10:45    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
@GremlinViewing profile: Gremlin
What is an "old" TDI?
Does my mass airflow sensor (MAF sensor) - 1Z - count as well?
At the very least, no disturbance rejection parameters can be obtained. Group 0 doesn't offer much anyway.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 11-10-2026, 20:42.
WarLord
Post08-11-2004, 21:23    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
'Older' TDI engines are TDI engines that use an injection pump.
Best regards, WarLord.
Harri
Post08-11-2004, 23:29    Subject: Weak Cylinders: Causes and Solutions Quote
Hello, what causes a cylinder to be stronger or weaker? In my case, VAG-COM sometimes shows +4.5 mg/stroke. That's quite a lot, and the car is having trouble starting. However, the compression should actually be okay. What else could cause these differences, such as worn injectors or a pump?
best regards, harri
Translated on 11-10-2026, 20:43.
Georg-TDI
Post10-11-2004, 13:29    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
My VAG COM sometimes shows +4.5mg/stroke. That's quite a lot, and the car is having trouble starting. The compression should actually be okay. What else could cause these differences, such as worn injectors or a pump?
The answer suggestions you already mentioned...
4.5 mg/R is not a little, but far too much! (Normal range: -2 to +2).
Causes:
- worn nozzles (most of the time)
- poor compression (rarely)
- ESP (even rarer)
Since you know where to look, get to work.
Best regards, Georg.
Translated on 11-10-2026, 20:44.
GarfieldMZ
Post10-11-2004, 21:41    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
Hello everyone,
I'm experiencing a similar problem with my AFB (6-cylinder VP44).
BUT in my case, one cylinder is deviating by a negative amount, not a positive one! I don't know exactly which cylinder it is, which is actually irrelevant... this one is giving me a value of around -2.5mg.
How can this be interpreted? All the other values fluctuate around a maximum of +/- 0.5mg. Are the other nozzles all that bad, or is this cylinder simply inherently that strong? icon_wink.gif
DENNIS
Translated on 11-10-2026, 20:46.
Post10-11-2004, 23:47    Subject: Cylinder Volume Difference: Analysis & Optimization Quote
Hello.
GarfieldMZ wrote:
Hello everyone,
DENNIS
Cylinders with a negative mass difference contribute more to the driving force. This indicates that either the reference cylinder is weaker, or the nozzle of the 'better' cylinder is dripping.
Translated on 11-10-2026, 20:47.
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts AKL Steuergerät: Readout & Field Explanations On-Board Diagnostics (OBD)
No new posts Pump Nozzle Elements: A Comprehensive Overview Diesel Engine Technology
No new posts 5-Cylinder TDI Engine: Performance & Specs Diesel Engine Technology
No new posts ASV as a 3-cylinder engine Diesel Engine Technology
