Load Stress in Idle: Is It Meaningless?
Go to page: 1, 2  Next
Post24-03-2005, 22:54    Subject: Load Stress in Idle: Is It Meaningless? Quote
My turbocharger is also building significant pressure even when it's supposed to be in bypass mode. For example, the LDA (likely a pressure sensor) shows 0.2 bar at 2000 rpm, even though there's definitely no boost pressure needed.
The corresponding logs show an actual pressure of approximately 1200 mbar, while the target pressure is approximately 1000 mbar.
What's the point of such a strategy?
To keep the turbocharger at a certain RPM in advance, so that when you accelerate fully, the pressure increase is only 2.1 bar instead of 2.3 bar?
That is, in my opinion, ridiculous icon_evil.gif.
By the way, my VTG (Variable Turbine Geometry) isn't stiff. If you look at the vane position of the logs (32% at 2000 rpm in boost), it becomes clear that this is intentional on the part of the developer.
Translated on 18-09-2026, 20:00.
Marco
Post25-03-2005, 1:14    Subject: Load Stress in Idle: Is It Meaningless? Quote
Hello Ulf,
While I don't have a technical background, I believe this is an attempt to minimize turbo lag when suddenly accelerating. Another idea would be to ensure constant lubrication of the turbocharger shaft by maintaining some degree of shaft movement.
Translated on 18-09-2026, 20:02.
Manuel Thomas
Post25-03-2005, 9:41    Subject: Load Stress in Idle: Is It Meaningless? Quote
I'm getting a meaningless 0.4 bar of boost pressure even at 4,000 RPM. I think it's to prevent that black cloud of smoke when I suddenly accelerate.
Manuel.
Post25-03-2005, 9:49    Subject: Load Stress in Idle: Is It Meaningless? Quote
Manuel Thomas wrote:
I even have 0.4 bar of meaningless boost pressure at 4,000 RPM.
I think this might help prevent the black smoke when I suddenly accelerate.
Well, according to the TDI-
theory:(, a TDI engine shouldn't produce soot because, with (still) too little boost pressure, the soot reduction system should kick in...
Only in practice does } sometimes turn out differently.
Translated on 18-09-2026, 20:03.
joegolf
Post25-03-2005, 11:27    Subject: Load Stress in Idle: Is It Meaningless? Quote
Does a turbocharger not always have to generate a certain amount of pressure?
On the exhaust side, it's always immersed in the exhaust flow and is driven by it. If no pressure were built up on the intake side, it would only be running against the resistance of the bearing friction and air turbulence. Wouldn't the speed increase to an unhealthy level in that case?
While in theory, no airflow would be needed in a "push" mode, and therefore no power would be required, the turbocharger would have to restart with every throttle input. Furthermore: Would you really want to climb a steep incline at full throttle and then descend the slope in "push" mode with a super-hot turbocharger that's no longer spinning???
So, he always has to rotate, and when he rotates, he needs some kind of "braking" force.
That's how I would imagine it, at least. icon_question.gif icon_question.gif icon_question.gif
Translated on 18-09-2026, 20:05.
Post25-03-2005, 12:36    Subject: Load Stress in Idle: Is It Meaningless? Quote
joegolf wrote:
Doesn't a turbocharger always have to generate a certain amount of pressure?
On the exhaust side, it is always located in the exhaust stream and is driven by it. If no pressure were built up on the intake side, it would only run against the resistance of bearing friction and air turbulence. Wouldn't the speed increase to an unhealthy level in that case?
Hm? I can't quite understand... it seems that the intake and exhaust volumetric flow rates are practically the same.
If a charger is still drawing energy to build up boost pressure, that's something akin to a perpetual motion machine icon_eek.gif icon_question.gif.
Furthermore: Climbing the slope with full power and then going down the slope in afterburner mode with a turbo that is extremely hot and no longer spinning???
Even a stationary engine would cool down quickly because it is constantly being flushed with cold intake air and (exhaust gases that are almost as cold) from the turbocharger.
And the oil circulation, which also provides cooling, should continue to flow even when the bearings are stationary... ?
Translated on 18-09-2026, 20:07.
wolfi_b
Post25-03-2005, 12:44    Subject: Load Stress in Idle: Is It Meaningless? Quote
joegolf wrote:
On the exhaust side, it is always located in the exhaust stream and is driven by it. If no pressure were built up on the intake side, it would only run against the resistance of bearing friction and air turbulence. Wouldn't the speed increase to an unhealthy level?
For this, there is a boost pressure control system using a wastegate or VTG.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 18-09-2026, 20:09.
Karma: +438 / -0   Thank you, like it!
Post25-03-2005, 12:45    Subject: Boost Pressure: Is It Necessary in Low-Load? Quote
ulf wrote:
The corresponding logs show an actual value of approximately 1200 mbar, while the target value is approximately 1000 mbar.
Looking at the throttle response of the engine (32% at 2000 rpm in boost), it becomes clear that this is an intentional design choice by the developer.
Hello Ulf,
Before we start wildly speculating about the developer's intentions or mistakes, or about the technical circumstances:
Have you checked whether the 32% PWM duty cycle actually has a significant effect? Have you tried disconnecting the solenoid valve and seeing if the low-pressure build-up is still almost 0.2 bar?
Guste.
Translated on 18-09-2026, 20:10.
Post25-03-2005, 13:06    Subject: Boost Pressure: Is It Necessary in Low-Load? Quote
guste100 wrote:
Have you checked whether the 32% PWM actually has a significant impact? So, have you tried disconnecting the solenoid valve and seeing if the low-pressure (LD) still builds up to almost 0.2 bar?
I did it differently, but the result is the same:
When the vacuum pressure in the VTG sensor is lower, the boost pressure effectively returns to zero.
Translated on 18-09-2026, 20:12.
donalexo
Post25-03-2005, 14:36    Subject: Load Stress in Idle: Is It Meaningless? Quote
Hi Ulf!
I suspect two things that might be responsible for an "aggressive" VTG (Variable Transmission Gear) setting in sliding operation:
1. Increase in engine braking force (increased boost pressure = higher exhaust back pressure).
2. Reduction of oil consumption (the gap seal on the compressor side is supported by the pressure gradient).
It is also possible that the transient behavior, i.e., the response characteristics of the ATL, should be positively influenced.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 18-09-2026, 20:13.
joegolf
Post25-03-2005, 14:41    Subject: Load Stress in Idle: Is It Meaningless? Quote
Okay, it's clear that in practice, he's still building up boost pressure during the idle phase. Either the engine is still injecting fuel during the idle phase, or the pump is being used.
Translated on 18-09-2026, 20:15.
Post25-03-2005, 14:42    Subject: Load Stress in Idle: Is It Meaningless? Quote
Ulf, why don't you play around with the accelerator a bit (both in a sporty/aggressive way and in a relaxed, cruising style).
I was at least surprised by what I consider to be a sensible behavior.
It seems that the MSTG is trying to determine whether the system is being used for heating or cruising.
Translated on 18-09-2026, 20:16.
Post25-03-2005, 15:15    Subject: Load Stress in Idle: Is It Meaningless? Quote
I also believe that the improved responsiveness (combined with reduced soot emissions at the end of the thrust phase) and the better sealing of the compressor are the reasons.
In motorsports, there was a time when left-foot braking became common practice with turbocharged engines. At the same time, the turbocharger was kept "spooling" by modulating the throttle. While this is only partially applicable to our tractors, I believe that maintaining a certain level of turbo boost will positively affect the responsiveness.
Translated on 18-09-2026, 20:17.
joegolf
Post25-03-2005, 15:22    Subject: Load Stress in Idle: Is It Meaningless? Quote
wolfi_b wrote:
For that, there is a boost pressure regulation via wastegate or VTG.
Okay, I understand. But VTG would have to almost completely seal the exhaust side if the turbocharger is running freely on the intake side. And then the turbocharger would run at undefined speeds until it stops. Even tiny air currents might be enough to keep the turbocharger running.
Alternatively: The plain bearings are likely the most vulnerable part during the turbo's startup phase. Therefore, repeatedly stopping the turbo during operation, even under load, is probably not a good idea. Furthermore, the oil would flood the turbo through the sealing rings if it were not running.
In order for the turbocharger to operate within a useful RPM range, it needs a certain amount of back pressure (boost pressure) that can be properly regulated (by the variable turbine geometry - VTG). With a boost pressure of 0 bar, the VTG lacks any control parameter. The turbocharger's RPM is not measured. Therefore, the turbo would either accelerate until it generates boost (possibly reaching 0.2 bar) or it would simply stop.
I hope I was able to make myself understood icon_smile.gif.
Translated on 18-09-2026, 20:19.
syncro peter
Post25-03-2005, 15:30    Subject: Load Stress in Idle: Is It Meaningless? Quote
Due to the plain bearings, the initial start-up of the turbocharger is likely to be the most wear-prone.
I agree. In this state, there's a mixed condition between a wave bearing and a plain bearing, and this operating condition should be avoided.
Translated on 18-09-2026, 20:21.
Günther
Post25-03-2005, 15:35    Subject: Load Stress in Idle: Is It Meaningless? Quote
Even in sliding mode, the engine pumps a significant amount of air, and the ATL (Anti-Lag Turbine) will never come to a complete standstill; the control range of the VTG (Variable Turbine Geometry) is simply not that wide. And in the process, it compresses the air slightly on the pressure side.
Günther.
Translated on 18-09-2026, 20:22.
No new posts A3 Doku: MKB ASZ Noise During Operation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Deviation in 2.5 TDI BDG Operation On-Board Diagnostics (OBD)
No new posts Starkes Rucken bei übergang zum Schubbetrieb Diesel Engine Technology
No new posts Strange Noises During Operation and Load Changes Diesel Engine Technology
No new posts Erratic behavior in low-speed operation - is the to blame? Diesel Engine Technology
