Diesel transmission on V6 gasoline engine: Possible?
dreiduke
Post27-11-2004, 1:39    Subject: Diesel transmission on V6 gasoline engine: Possible? Quote
hi
apart from the effort.
Is it possible to install a 6-speed Audi diesel transmission into an A4 2.8 V6 quattro with 174 hp without making significant modifications?
Besides the fact that, due to the lack of torque in the lower range, you would need to use more clutch to start, and in 6th gear, you certainly wouldn't be able to reach the maximum engine speed due to a lack of power.
Translated on 02-09-2026, 21:41.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Diesel to Gas Gauge Cluster Swap: Possible? Diesel Engine Technology
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
No new posts Fuel consumption for gasoline engines? Diesel Engine Technology
No new posts BFQ 1.6 Petrol Engine Gasoline Engine Technology
