Label-Files for VAG-COM / FB to ZV
Günni
Post29-11-2004, 1:16    Subject: Label-Files for VAG-COM / FB to ZV Quote
Hello, first of all,
Unfortunately, I haven't been able to find anything on this topic using the search function.
I am looking for label files for the VAG-COM 311.2-N for the following ECUs:
Engine Control Unit 038-906-018-FS 1.9l R4 EDC 000SG 3103
ABS/ESP Control Unit 8D0-907-389-D ABS/ESP front D36
Combination Instrument 3B0-920-802-A B5-Combination Instrument. VDO V25
All components are in a Passat 3B, year of manufacture 6/2000, 1.9l TDI 90hp, Engine Code: AHH
installed.
Unfortunately, I couldn't find anything (Rosstech, etc.). Does anyone have these available and could send them to me by email? I would be very grateful.
And now my second. Question:
Can a key be programmed to the comfort control unit (1J0-959-799-Q, coding 04097)? The car was originally equipped with central locking without a remote key. A friend told me that something like this works.
Thank you in advance!
Theresias
Post29-11-2004, 4:23    Subject: Re: Label-Files for VAG-COM / FB to ZV Quote
I'll add the ECU to my list when I'm finished with it, then see the website for download.
Is it possible to program a remote key on the comfort control unit (1J0-959-799-Q, coding 04097)? The car was originally equipped with central locking without a remote key. A friend told me that something like this works.
Besides that, the part number is incomplete (the index is missing), no, this control unit does not have/support FFB.
Günni
Post29-11-2004, 11:38    Subject: Re: Label-Files for VAG-COM / FB to ZV Quote
Thank you for the quick response.
Theresias
Post29-11-2004, 20:27    Subject: Label-Files for VAG-COM / FB to ZV Quote
Regarding the speedometer, can I get your help...?
- Part number
- Coding
- Available adjustment channels (preferably with values)
- Available measurement blocks (preferably with values)
*edit*
Here is the file for the AHH, it should be used with the current VAG-COM version 409.0 or 409.1, as otherwise, correct functionality cannot be guaranteed.
Simply copy the two files into the VAG-COM subfolder /labels/.
http://download.openobd.org/labelfiles/03-01.lbl
http://download.openobd.org/labelfiles/german/038-906-018-AHH.lbl
If you are using an older version (before 405.0), you need to adjust the filename of 038-906-018-AHH.lbl accordingly. Also, not all information may be available.
*edit²*
And now also the files for ABS, as above also applies:
The files for your ABS should be used together with the current VAG-COM version 409.0 or 409.1, as otherwise, proper functionality cannot be guaranteed.
http://download.openobd.org/labelfiles/4B-03.lbl
http://download.openobd.org/labelfiles/german/8D0-907-389.lbl
Renaming in relation to older VAG-COM versions is not necessary in this case (except for 4B0 907 389 control units).
Theresias
Post05-12-2004, 18:33    Subject: Label-Files for VAG-COM / FB to ZV Quote
Okay, I'm ready. Please provide the text you want me to translate, keeping all s exactly as they are. I will only provide the translation, no explanations.
No new posts VCDS 805: Fewer XPL Files for Faster Performance On-Board Diagnostics (OBD)
No new posts Label File für STG 038-906-019!!! Diesel Engine Technology
No new posts Label-Dateien Diesel Engine Technology
No new posts Label Datei On-Board Diagnostics (OBD)
