AFB V6 TDI - When to stop fueling?
audi
Post08-12-2004, 21:39    Subject: AFB V6 TDI - When to stop fueling? Quote
How do I precisely set the start of the flow after a pump change?
does anyone have a link, or can they explain it to me in detail?
it is an A4 V6 TDI 150 hp AFB engine
it is quite important that it is accurate.
thank you
Post08-12-2004, 21:56    Subject: AFB V6 TDI - When to stop fueling? Quote
Welcome, Audi,
That is perfectly described in these articles on this page. (Search function: Only search in the "Fachartikel" category with the term "*spritzbeginn")
Greetings
Guste
PS: Was ist mit dem Benutzernamen? Ist er noch verfügbar? I can't believe it...
Julian
Post08-12-2004, 22:02    Subject: AFB V6 TDI - When to stop fueling? Quote
Welcome to Audi,
That is perfectly described in these articles on this page. (Search function: Search only in 'Fachartikeln' with the term '*spritzbegin')
Sorry, am I being blind or can't I find the instructions there? Only for VP37... but VP44?
Post08-12-2004, 22:52    Subject: AFB V6 TDI - When to stop fueling? Quote
Julian wrote:
...Specifically for VP37...but what about VP44?
Okay, but shouldn't the procedure be identical for both, or? Use Vag-Com, compare "Target/Actual," turn the pump on, compare "Target/Actual," etc., until Target=Actual. Please correct me, Julian, if I am wrong.
Greetings
Guste
audi
Post08-12-2004, 23:01    Subject: AFB V6 TDI - When to stop fueling? Quote
the pump cannot be turned!
it is securely mounted.
I have already secured the old pump and removed it, i.e., the motor is on cylinder 1.
and now I want to install a new one, which I will of course also lock beforehand. Do I need to adjust anything at all, or can I just put it in together and hüh hüh?
Post09-12-2004, 20:08    Subject: AFB V6 TDI - When to stop fueling? Quote
Audi states:
- Just install the pump
- check with VAG-COM SB
Optional:
- Remove the timing chain tensioner
- Loosen the camshaft, turn left for later, right for earlier
- review and adjust as needed until it's perfect.
Absolutely no way to open the ESP-ring!
Busy working,
Guste
audi
Post09-12-2004, 20:45    Subject: AFB V6 TDI - When to stop fueling? Quote
many thanks. will I probably get my pump tomorrow?? I'm curious to see how everything works. I'm building a pump from a switch into an automatic system, but the Bosch numbers are the same.
Manuel V
Post10-12-2004, 20:56    Subject: AFB V6 TDI - When to stop fueling? Quote
Look under:
/viewtopic.php?t=4816&highlight=injection+start+adjust
+ Additionally, disconnect the fuel pump, place the timing belt (ESP), and align the markings icon_lol.gif
Check dynamic injection start.
I'm curious to see how you'll bleed the VP44.
Manuel
roli752001
Post10-12-2004, 22:37    Subject: AFB V6 TDI - When to stop fueling? Quote
Regarding the topic of venting, I always do it like this
Install EP, timing belt not yet installed, attach all hoses to the pump, leave the nozzles loose, turn the ignition on and then turn the pump by hand (it's easy), you can 'HEAR' it working, until the air in the return line is gone or it starts to drain out of the nozzles, disconnect, re-install, tighten all hoses and make sure they are even (without using a drill icon_smile.gif), start the engine, check with vag FB, if not exactly 3 screws need to be loosened without loosening the tensioner, correct, tighten and check.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Set Grant Start Date Diesel Engine Technology
This topic is locked, you cannot edit or reply. Start subsidy, model 1Z, year of manufacture 1996 Diesel Engine Technology
No new posts ARL: Set Start Date for Grants. On-Board Diagnostics (OBD)
No new posts 1.6 TDI: Adjust Power & Injection Timing Diesel Engine Technology
