V6 TDI AGR: What is it?
denni
Post16-12-2004, 13:31    Subject: V6 TDI AGR: What is it? Quote
Hello! I've read a lot about the AGR already, and I'm almost certain I know where the famous metal piece needs to go.
But it's only ALMOST icon_eek.gif.
That's why I'm asking again, just to be sure icon_redface.gif.
Because I haven't been able to find a clear picture of a V6 TDI engine that precisely identifies all the parts icon_cry.gif.
Now, my question: Are the spots in the picture the correct places where the sheet metal needs to be inserted icon_question.gif 1 or 2? Although only one spot is needed!
http://www.ewetel.net/~d.o.w/agr.jpg
THANK YOU !!!!!
ps. Great forum icon_wink.gif.
Translated on 09-09-2026, 20:28.
cetano
Avatar-cetano
Post16-12-2004, 16:11    Subject: V6 TDI AGR: What is it? Quote
It doesn't really matter (whether it's one or two), because nothing is flowing anyway.
Further criteria would include:
1. What's the best way to reach you?
Where is the thermal stress (and thus, potentially, corrosion) lowest?
I would guess option 2 (the cross-section to be closed off there is also smaller, and you are in a "cleaner" area).
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 09-09-2026, 20:29.
Back to top Profile PM Email
denni
Post16-12-2004, 16:22    Subject: V6 TDI AGR: What is it? Quote
OK! Thank you icon_smile.gif.
I will then get started on it tomorrow icon_eek.gif.
Translated on 09-09-2026, 20:30.
Marco
Post16-12-2004, 21:29    Subject: V6 TDI AGR: What is it? Quote
Hi, here's one more small tip about that.
If you want to install the plate directly on the EGR valve (2), you should make sure your tools are securely fastened.
'An the same location, an Allen wrench fell into the 'V' of the engine. It took me about an hour to get it out. I would install the bracket directly on the intake manifold because it's easier to access there, and the required bracket is also smaller.'
Translated on 09-09-2026, 20:31.
denni
Post16-12-2004, 21:59    Subject: V6 TDI AGR: What is it? Quote
@marco! Yes, you're absolutely right. I've had that problem with tools falling down many times; it's awful.
I have also taken another, more careful look at it, and I will probably attach the plate to position 1 because of the easier accessibility. icon_rolleyes.gif
Translated on 09-09-2026, 20:32.
