Oil Pan Plug Tricks: Easy Removal Tips
Post10-01-2005, 8:48    Subject: Oil Pan Plug Tricks: Easy Removal Tips Quote
Hi.
I've been lying under the oil pan for half a day and I can't get these two stupid screws into the flywheel (the ones that require a torque wrench... if you can even get them properly aligned).
How did you do that?
Can anyone give me some tips on how to get those things inside?
Thank you.
Translated on 06-09-2026, 9:43.
Benno
Post10-01-2005, 19:18    Subject: Oil Pan Plug Tricks: Easy Removal Tips Quote
Hello.
Do you also have the correct screws? The two screws that go in there have an internal Torx recess and can be tightened with a Torx screwdriver.
Good luck.
Benno.
Translated on 06-09-2026, 9:44.
Benno
Post10-01-2005, 19:24    Subject: Oil Pan Plug Tricks: Easy Removal Tips Quote
I need to correct myself: It's not a Torx screw, but an Allen screw.
You need to use a round-head Allen key.
Benno.
Translated on 06-09-2026, 9:45.
Post11-01-2005, 1:13    Subject: Oil Pan Plug Tricks: Easy Removal Tips Quote
Everything is neither/nor. And it was finished tonight icon_smile.gif.
The screws had a SW10 (socket wrench) size on the outside and a Torx 40 size on the inside.
To make sure these two "stupid" things fit together properly, I bought new ones.
They only have SW10 available externally.
(I had Allen wrenches for my Golf 2.)
"Nevertheless, thank you."
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Fuel injectors for 130 PD? Diesel Engine Technology
No new posts ESD Spacer Washers: Secure & Protect Diesel Engine Technology
No new posts LOGIN Code for AEL Diesel Engine Technology
