Error code? 001423
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
mansab
Post11-01-2005, 18:59    Subject: Error code? 001423 Quote
Can someone please explain error code 001423 in plain language? It's constantly illuminating the ESP lamp on my Golf 4 (year 2000).
Thank you.
Manfred
Theresias
Post11-01-2005, 19:25    Subject: Error code? 001423 Quote
i.d.R. VAG-COM already provides the plaintext:
01423 - Sensor for Lateral Acceleration (G200) - electronic. Fault in the electrical circuit
< Sensor installation for transverse acceleration (G200)
< Sensor for Lateral Acceleration (G200) is defective
< Interruption/Short circuit/Loose connection between the sensor (G200) and the control unit (J104)
> Verify the installation location of the sensor for lateral acceleration (G200)
> Check the lateral acceleration sensor (G200)
> Replace the lateral acceleration sensor (G200)
> Perform initial setup
01423 - Sensor for Lateral Acceleration (G200) - Unrealistic Signal
Karma: +791 / -0   Thank you, like it!
Post11-01-2005, 19:28    Subject: Re: Error code? 001423 Quote
mansab wrote:
Could someone please explain error code 001423 in plain language? It's causing the ESP (Engine Stability Program) light to stay on constantly in my 2000 Golf 4.
Thank you.
Manfred
You could also have typed in the search function with '*1423'...
Hello, Rainer
Post12-01-2005, 10:16    Subject: Error code? 001423 Quote
Wow, that sounds like a lot of $$$$. That's good that I cancelled the ESP on my Polo icon_cool.gif
OT, I know -> *duckandwayrun*
