chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
23-04-2012, 13:35 Subject: VW LT 2.4 TDI: Specs, Review & Price |
Hello!
I'm having a problem with my VW LT 2.4 TDI, 6-cylinder engine.
When the engine is warm and you've driven about 10-15 km, a little bit of black smoke comes out of the exhaust under load, which is apparently normal.
When the engine is then turned off for about 10-15 minutes and restarted, and the accelerator is pressed, it emits a large amount of blue-white smoke and smells strongly of unburned oil.
The turbocharger starts to build boost very slowly, beginning around 3000 RPM, and I only reach approximately 0.6 bar at around 4000 RPM. I also noticed a little bit of oil in the exhaust.
The shaft seals have been replaced, and the engine performance is fine. There is no oil in the coolant, and no coolant in the oil.
The diesel pump was set to 0.85.
Does anyone have a tip for me? A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 23:53.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
23-04-2012, 14:10 Subject: VW LT 2.4 TDI: Specs, Review & Price |
Quote: | I also had a little oil in the exhaust.
Determine whether the oil is coming from the engine itself or from the turbocharger (TL).
Possibly bypass the turbocharger from the engine control unit and check it, or run the engine and see if it's producing any smoke.
Check the charger for wear and tear (e.g., damaged shaft, leaks). LG, Onkel BM
Translated on 30-10-2026, 23:54.
chriskross Blaumann
23-04-2012, 15:13 Subject: VW LT 2.4 TDI: Specs, Review & Price |
I'm going to try starting without using the turbo.
If it were actually the turbo, shouldn't it be producing smoke while driving? A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 23:55.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
23-04-2012, 21:23 Subject: VW LT 2.4 TDI: Specs, Problems, & More |
chriskross wrote: | Hello!
I'm having a problem with my VW LT 2.4 TDI 6-cylinder vehicle.
When the engine is warm and you've driven about 10-15 km, a little black smoke comes out of the exhaust when under load, which is acceptable.
The turbo boost starts to increase very slowly from 3000 RPM, and I only reach 0.6 bar at around 4000 RPM. I also noticed a little bit of oil in the exhaust.
The diesel pump was adjusted to 0.85.
Does anyone have a tip for me? |
Are you sure it's a 2.4 TDI 80? It's more likely to be a 2.4 TD!
LD starts late! The turbocharger turbine shaft can be easily inspected by removing the intake hose, and a mirror can be used to precisely check for damage.
Occasionally, remove the crankcase ventilation hose from the intake manifold and check for signs of excessive oil. A light oil film is normal.
I experienced a similar effect on my T3 1.6TD. There was a lot of smoke after starting, but after some time, as the exhaust manifold got hotter, the smoke gradually decreased (the oil burns cleaner).
Another question: How does the engine start? NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 30-10-2026, 23:57.
Profile PM Email Garage |
chriskross Blaumann
23-04-2012, 21:41 Subject: VW LT 2.4 TDI: Specs, Review & Price |
Hello, it's a 2.4 TD with 70 kW, manufactured in 1995, ACL.
Starting behavior is good.
The intake manifold is already oily. Did your turbo fail, or at what point should the boost pressure start?
The linkage for the turbo seems a bit stiff. A6 AFB
A6 BRE DPF
Translated on 30-10-2026, 23:59.
chriskross Blaumann
24-04-2012, 8:04 Subject: VW LT 2.4 TDI: Specs, Review & Price |
I've now removed the turbocharger, and there are clear signs of oil residue and oil droplets visible inside the exhaust pipe. A6 AFB
A6 BRE DPF
Translated on 31-10-2026, 0:00.
