Engine won't start, stalls at traffic lights
schnuepperle
Post11-01-2005, 15:37    Subject: Engine won't start, stalls at traffic lights Quote
Hello, esteemed experts. I'm having a problem with my Golf III Variant, diesel, 55 kW, manufactured in 1994, and I'm hoping for your help.
On a colder day, it was very difficult to start. After a highway drive (80 km), I stopped the car for ten minutes. Then, the same thing happened again. And when slowing down at a traffic light, the engine speed suddenly dropped, and the car stalled several times. After that, it only started again with the 'choke' fully engaged. Also, it has been smoking heavily since these incidents.
What could be the problem, and how can I fix it?
Thank you for the tips.
Best regards, Schnüpp.
Translated on 08-09-2026, 10:38.
golfschrauber1981
Post11-01-2005, 20:37    Subject: Engine won't start, stalls at traffic lights Quote
Attention: Do not start the process again under any circumstances!
It sounds like the crankshaft pulley has detached, which usually means the valve timing is extremely misaligned, specifically retarded.
Okay, first, check if the crankshaft pulley bolt can be turned. (The bolt is located on the belt side, in the center of the large pulley. It's a 12-point bolt and should be able to be turned with a standard open-end wrench.) However, the bolt should normally be tight enough that it won't budge.
Okay, and just to check, the fifth gear and the handbrake, or the special locking device, which probably isn't there.
If that's the case, my condolences, because that means the timing belt pulley on the crankshaft failed, and it's possible that the pistons and valves have already collided.
Did the engine make a loud, metallic knocking sound at the end?
Once the screw is tightened, check the valve timing.
But even if it's confirmed that the screw is tight and the valve timing is correct, it still won't start. Maybe there's still something we can salvage.
It would also be interesting to know the mileage and whether the timing belt has already been replaced.
Translated on 08-09-2026, 10:40.
golfschrauber1981
Post14-01-2005, 19:14    Subject: Engine won't start, stalls at traffic lights Quote
And how about it?
Sure, here's the translation:
'I would appreciate feedback.'
Translated on 08-09-2026, 10:42.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts 1.9 TDI BLS engine stalls at traffic lights when the engi... Diesel Engine Technology
No new posts VW Polo 1.4 TDI: Starting Issues, Misfires, Stalling Diesel Engine Technology
No new posts Sharan: Starting problems & engine stalls. Diesel Engine Technology
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
