Diagnostic Cable Issues: 20m Cable Not Working.
Sven@G4H
Post01-08-2005, 20:18    Subject: Diagnostic Cable Issues: 20m Cable Not Working. Quote
"Today, I built the diagnostic interface version 2.4 using optocouplers. VCDS recognizes the adapter, and the LEDs and other functions work as expected, just like the baud rate test with the adapter test software. However, the control unit of my Golf 4 TDI, manufactured in 1998, is not responding. Since I don't have a laptop, I connected everything via a 20-meter network cable. Could this be the reason why it's not working? If so, what can I do to make it work?"
-regards-
Translated on 09-09-2026, 5:40.
Post01-08-2005, 21:30    Subject: 20m Cable to Diagnostic Interface: Troubleshooting Quote
Sven@G4H wrote:
"Today, I built the diagnostic interface, version 2.4, using optocouplers! VCDS recognizes the adapter, and the LEDs and other functions work as expected, just like the baud rate test with the adapter test software! However, the control unit of my Golf 4 TDI, manufactured in 1998, is not responding. Since I don't have a laptop, I connected everything using a 20-meter network cable. Could this be the reason why it's not working? If so, what can I do to make it work?"
-mfg-
It's better to move the PC to the garage. Is the OBD2 connector properly connected? My customers sometimes get the pins on the diagnostic connector mixed up (reversed). icon_smile.gif
Translated on 09-09-2026, 5:42.
Sven@G4H
Post02-08-2005, 10:32    Subject: Diagnostic Cable Issues: 20m Cable Not Working. Quote
The pins are definitely connected correctly! Why does it stop working when using a longer cable?
-regards-
Translated on 09-09-2026, 5:43.
Post02-08-2005, 11:23    Subject: Diagnostic Cable Issues: 20m Cable Not Working. Quote
Sven@G4H wrote:
The pins are 100% correctly connected! Why does it stop working with a longer cable?
Perhaps the trimmers on the adapter are adjusted in such a way that the communication with a shorter cable just barely works, but the capacitance of longer cables leads to unacceptable delays in the signal edges.
Sven@G4H
Post02-08-2005, 17:28    Subject: Diagnostic Cable Issues: 20m Cable Not Working. Quote
Okay, it's working now! I experimented with the trimmer setting again, and now I can connect either a 1.5-meter cable or a 20-meter cable, and it works with both!
-regards-
Translated on 09-09-2026, 5:44.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Diagnostic Cable: Which One is Best? On-Board Diagnostics (OBD)
No new posts Valve cover gasket leak - unfortunately, also on the timi... Diesel Engine Technology
No new posts Important: How it works, Terms of Use Upload
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
