TDI Injectors: V6 Differences Explained
altonno
Post20-01-2005, 18:39    Subject: TDI Injectors: V6 Differences Explained Quote
Hello guys,
Can anyone tell me what the differences are between the injector nozzles with needle lift control and those used in the V6 TDI engine? Specifically, I'm referring to part numbers 059130202B and 059130202C. The first one is for a manual transmission AKN engine, while the second is for an automatic transmission AKN engine.
Aber worin unterscheiden die sich? Ist der NHG anders? Die Düsenbohrungen? What is the operating pressure?
Are they compatible with each other? Can I also use part number 059130202C in my AKN manual transmission?
"Hello."
AL
Translated on 25-08-2026, 10:11.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
This topic is locked, you cannot edit or reply. ACV vs. AFN Injectors: What's the Difference? Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI vs. TD: What's the Difference? Diesel Engine Technology
No new posts Volkswagen Golf 1.9 TDI 74 - 77 kW Diesel Engine Technology
No new posts ALH vs. AFN Engine: Differences and Specs Diesel Engine Technology
