Audi 80 1Z: Timing Belt Replacement Guide
thom
Post14-09-2004, 17:08    Subject: Audi 80 1Z: Timing Belt Replacement Guide Quote
Hello.
I'm planning to have my timing belt and all the related components replaced soon.
So, I went to my parts supplier and bought the whole kit.
My problem is that there are two different kits available for the car. I know that sometime in 1994, a different 1Z engine was installed with slightly more torque. Mine is from late 1993, so it should be the older version.
So, one kit covers up to engine number 289575, and the other one goes beyond that.
Unfortunately, there's nothing about it in my service booklet because the car was originally imported from Germany.
Where can I find this number without having to remove the entire engine splash shield?
Thomas icon_rolleyes.gif.
Translated on 18-08-2026, 6:17.
Back to top Profile PM Email
faz
Avatar-faz
1994 Audi 80
Post14-09-2004, 22:06    Subject: Audi 80 1Z: Timing Belt Replacement Guide Quote
Do you have the mass airflow sensor or the air flow meter installed?
Mass airflow sensor, rather round in shape. Found in the newer 1Z models.
http://home.arcor.de/f.bichlmeier/dforum/LMassenM.jpg
Air flow meter, very rectangular shape due to the bypass valve. Used in older 1Z models.
http://home.arcor.de/f.bichlmeier/dforum/LMengenM.jpg
If necessary, I can send you a picture of the engine compartment so you can compare everything and see if it's the older or newer 1Z model. But the Mass Air Flow sensor (MAF) should be enough to distinguish between them.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 18-08-2026, 6:19.
thom
Post15-09-2004, 7:18    Subject: Audi 80 1Z: Timing Belt Replacement Guide Quote
Okay, so I installed the lower part of the image you sent. It's probably the older version, which is likely the timing belt kit with a specific number on it.
Translated on 18-08-2026, 6:20.
Post24-01-2005, 15:38    Subject: Audi 80 1Z: Timing Belt Replacement Guide Quote
WARNING.
In the G3 model, the tensioner was changed in 1995 – so at that time, the motor number exceeded this limit.
Here:
Sure, here's the translation:
"Is there any more information available?"
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Leaking oil lines, all V6 TDI engines up to mod... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 V6 TDI: Tips & Tricks for Owners Diesel Engine Technology
No new posts 1. 9 TDI & 1.5 TDI: Tips & Tricks for Drivers Diesel Engine Technology
No new posts A Request to All A6 C4 AEL/AAT Drivers Diesel Engine Technology
No new posts To an AEL driver Diesel Engine Technology
